197? Sea Nymph
JGibson
197? Sea Nymph
Post by JGibson »
Found this today on CL, it's close to home too. Supposed to be going to look at it tomorrow. 197? (He wasn't sure on the year) Sea Nymph with Trailer, 40HP Johnson Seahorse (Does not run), the head has been unbolted. Boat is 14ft long, 4ft wide in floor & 6ft wide on top. This is the way the guy bought it with intentions to fix it up but he now wants something bigger (18ft Flat bottom). $700, think its worth it?
1979 Monark 1443, 1969 Johnson 18Hp Motor
JMichael
197? Sea Nymph
Post by JMichael »
Since the motor isn't running and the heads been removed, you're counting on a lot of good luck there. The boat looks a bit run down on the interior although the hull looks pretty good with no dents showing in the pics. The trailer looks like it's going to need a bit of work to get it in shape as well. I'd want to see the boat filled with water to check for leaks before I handed over any money. Prices vary depending on what part of the country you're in but I'd try offering 450-500 if I thought I wanted it for a project.
JGibson
197? Sea Nymph
Post by JGibson »
This boat started out at $1000 and he dropped it to $700. My father in law has the exact same motor that is on it but it needs bottom work. I think I'll offer $500 and see what he says. 8)
JGibson
197? Sea Nymph
Post by JGibson »
Went and looked at the boat today. It is actually in alot better condition than the pics show. The motor is locked up but my father in law has the exact same motor so that will be an easy fix. Floors, decks, transom are all in good shape. 4 seats/poles are a little ragged. Steering/Throttle cables all work. Boat had water in it from the rain so that let me know it didn't have any holes that would sink it :D A few odds and ends and it should be ready for the water. Gonna go and pick it up tomorrow evening if it hasn't sold before #-o . He came down to $600, wouldn't go any lower [-X
JGibson
197? Sea Nymph
Post by JGibson »
Boat is a 1983 and the motor is a 1976. 14ft long, 4ft in the floor, 6 on top rib. Trailer is in real good shape, just needs a good coat of paint. I'll post some better pics tomorrow.
