ky_madman
- Joined
- Feb 5, 2008
- Messages
- 54
- Reaction score
- 0
I'm putting in a cooler-type livewell. How do I run the drain? Can I "T" it in to the bilge pump hose?In the cooler I've got a line coming in from the back to fill the well. Then, I have a pump in the bottom of the cooler, going to an aerator pipe in the top. Then I've got a drain in the bottom and an overflow in the top, these will be tied together. Where do I run this drain, without putting another hole in the boat.....and how do I push the water out? Any and all suggestions are appreciated.
Thanks
Thanks
