Question about using zinc brackets for aluminum mods
SpartanAngler
Traverse City, MI
I am trying to do a small mod on a small budget with readily available items. Is it possible to prevent the corrosion from zinc on aluminum with something simple like a thin sheet of rubber? For example cut pieces of shower pan lining, or red rubber gasket sheets in between the brackets and the boat. Just want to know if this would help at all.
