A day at work
CaseyP
Mooringsport, LA
I figured I would take some pictures today while I was at work.
After I installed to hds 5 with structure scan and cut the grip tape to cover the old holes. I had a load of boats to unload, 5 in all.
Then one I've never seen before, a foot controlled trolling motor on the front of a piroque. 46lb motorguide to be exact.
That a little bit of what I do on a daily basis.
only saw the first pic but looks like you do have a good job. I don't know if it was the internet or the way you posted it but don't feel bad. $hit happens.
I see all of the pics but there's a problem with that first pic, the speedometer is on 0. Even though I saw all the pics, I'm not sure what all I saw. I'm guessing a piroque is that thing that looks like a weird canoe but what is it for?
Yeah the weird looking canoe is a piroque. On the console of the Nitro Z-7 I had to cut out grip tape to cover up holes that were in the console and then install the Lowrance HDS5 on a ram mount. I should have taken a pic of the load of boats before I unload 2 of them, they are stacked 2 high and crooked on the trailer. It can be a pain unloading them when you don't have a hoist to unload them, just a fork lift.
