87 Tracker Casting Deck Mod
87Bass-Tracker
Post by 87Bass-Tracker »
New to the forum here. I extended the casting platform in my 87 Bass Tracker and added a rod locker and a few storage compartments. Thought I would share a few pictures if anyone had the same boat and ever contemplated doing the same. Everything worked out well so far. Just need to finish the doors and add a few finishing touches.
NaturalLaw
Post by NaturalLaw »
looks great! and it's professionally carpeted on the inside ;)
1974 Starcraft Mod-V
1972 Johnson 4hp
g7evans
Post by g7evans »
Looks great. I have a 16ft sylvan with a similar set up (before you mod) and would like to extend the casting deck back to the console. What did you use to attached the 2x4's to the floor of your boat?
Kochy
Post by Kochy »
I have that same boat, and I was thinking about doing that to mine, but I'm not real sure of doing it, cause the carpet I used is discontinued, so I couldn't match the carpet.
Here's a link to my build if you want to check it out.
https://www.tinboats.net/forum/viewtopic.php?t=23955
Hey if you wouldn't mind could you possibly take a picture of the outside of your boat and inside? The guy who had my boat before me added bedliner on the side and I'm debating on taking it off and I'd want to see what it'd look like.
