Screws and Seat Clamps.
Tompatt
Macon, GA
I have my seats all on their own piece of plywood. i guess im gonna just screw them into the bench. wat kind of screws should i use? where can i find them? idk if i should screw them becuz i may take them out and put them bak in every now and then. do yall think i should just stick with this plan or go to bass pro and get those seat clamps? wat r the pros and cons of them?
Get the wide seat clamps, that way you can remove the seats when you need/want to. Plus with the clamps you can move the seat to the left and to the right instead of it being in 1 spot all the time.
wide seat clamps? do u have a link or photo of them?
https://www.basspro.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10151&catalogId=10001&langId=-1&partNumber=948&hvarTarget=search&cmCat=SearchResults
i dont like the looks of that lol. how bout this https://www.basspro.com/webapp/wcs/...1_16127_200004009_200000000_200004000_200-4-9?
On my Grumman, I had the seats mounted onto a piece of 3/4 inch plywood. Then, I would put that on the bench seat, and strap it down with 15 foot ratchet straps. Worked well, was removable, adjustable, and when I went to sell the boat, I was able to sell it w/o holes in it.
Here's the clamp I used. I replaced the Wing Nuts with standard nuts. I didn't think I could tighten the clamp tight enough to hold my 210Lbs :lol:
https://www.cabelas.com/cabelas/en/templates/product/standard-item.jsp?_DARGS=/cabelas/en/common/catalog/item-link.jsp_A&_DAV=SEARCH&id=0013304017376a&navCount=2&podId=0013304&parentId=&masterpathid=&navAction=push&catalogCode=IJ&rid=&parentType=&indexId=cat21336&hasJS=true
yea i think thats about how big the plywood is. if i was gettin a clamp i would get the one i posted. which would be better the plywood or clamp?
