1984 16' Bass Attacker Complete Rebuild
Boating related questions, small projects, custom work and talk go here.
Bigwrench
Post by Bigwrench »
New guy to the Forums from SWVA/East Tn area . Have spent hours the last few days reading through some of the amazing posts on the site so thank you all in advance for a great resource !
I belong to a fishing website and after several recommendations to come here for info , I decided this is the place to ask questions about my project. Hopefully I can help someone else who is looking for guidance and learn a few things along the way. I apologize in advance if this is in the wrong section and Admin feel free to move it if so. Thank you
I got this 1984 Bass Attacker by Sea Nymph boat off of my neighbor by trading 5 oil changes on her SUV ! We had kicked around a price for a couple years and she decided that's what she wanted so it is now mine with very little initial investment. It has a 55 HP Nissan 2 Stroke that runs great ( more on that later).
The boat had about 18" of water in it when I hooked it up to move it so found a steep hill and drained it , it was full of leaves and junk and all the wood was rotted and the foam was saturated.
My ideas are to strip it down to the aluminum check it for leaks and repair any issues that are present . Im not sure if I want to replace the floor with wood or aluminum yet . I would prefer Aluminum with some sort of Non Slip coating just for ease of cleaning it. The boat was seriously neglected by her teenage boys and is in need of some serious TLC.
I started out by removing all the floor decking and anything that had to be removed to get me to that point
Bigwrench
Post by Bigwrench »
Got everything off of it last night and I'm down to the metal floor and the foam
I found rot in the transom wood so tonight the motor comes off and ill start working on removing that as well
As well as removing all the water logged foam and getting it ready for a good cleaning and pressure washing inside. What do you guys recommend ? I've read aluma bright (acid) and saw on here someone used CLR ? I thought maybe purple power and let it soak in and then pressure wash it off but wanna do it right.
smackdaddy53
Post by smackdaddy53 »
Sandblast it! Gets in the cracks and crevices. Definitely the way to go if you have access or know somewhere to get it done.
~Mac~
Bigwrench
Post by Bigwrench »
smackdaddy53 wrote:Sandblast it! Gets in the cracks and crevices. Definitely the way to go if you have access or know somewhere to get it done.
That would be best , I'd bet it would look clean too maybe a media blast like walnut shells or some fine sand ? May have to buy a sand blaster now lol. Also wanted to ask you about your riveting tool the solid rivet one "Bucker?" I have several air hammers and might need to look into this. Also have a pneumatic riveter and a "Big Daddy" so I should be good on regular rivets. Looking for a local source for alum plate now. Thanks again , your post gave me a ton of ideas lol. Right now I want to get it stripped , get it clean and them come up with a plan
This will be my Muskie,Striper,Crappie and Walleye rig that I can troll or cast for bass or whatever either on the lake or the river. Also exclusively for 2 lakes with no gas rule at 3500+ feet elevation on top of mountains locally here that are impossible to get up to with the Ranger.
smackdaddy53
I took a cheapo air chisel from Harbor Freight Tools and cut the end off one of the chisels, drilled the end with a 1/2" drill bit, buffed it smooth and it has a perfect concave tip to fit solid rivets. I drilled a few indentations in a $7 log splitting wedge and used that for a bucking bar. Works perfect
~Mac~
Bigwrench
Post by Bigwrench »
smackdaddy53 wrote:I took a cheapo air chisel from Harbor Freight Tools and cut the end off one of the chisels, drilled the end with a 1/2" drill bit, buffed it smooth and it has a perfect concave tip to fit solid rivets. I drilled a few indentations in a $7 log splitting wedge and used that for a bucking bar. Works perfect
That's awesome ! Gonna work on that tomorrow at work lol. I have about 30 different types of chisels and hammers and punches for my air hammers. Thank you yet again !
JMichael
Post by JMichael »
If you look through my build and see how well it worked for me, you'll understand why I'm a big fan of the Alumabrite. It's tremendously cheaper, unbelievably faster, and an order of magnitude easier than doing it with a sandblaster. Of course you can always ignore all of those facts and just go with the fact that it's a darn good excuse to go buy another tool. I mean what man in his right mind would turn down the opportunity to buy a new tool??? :lol: I am a tool nut after all. :mrgreen:
Moondog
Post by Moondog »
smackdaddy53 » 01 Apr 2014, 21:26 wrote:I took a cheapo air chisel from Harbor Freight Tools and cut the end off one of the chisels, drilled the end with a 1/2" drill bit, buffed it smooth and it has a perfect concave tip to fit solid rivets. I drilled a few indentations in a $7 log splitting wedge and used that for a bucking bar. Works perfect
This sounds like an excellent way to tighten up rivets.
Bigwrench
Post by Bigwrench »
Time to update .
Removed all of the foam got the motor off and rotted out transom is history.
Down to a bare aluminum hull and I have a pressurized sand blasting tank and just have to acquire some media that will not be too harsh on the hull.
Getting pretty excited about the build as it is now in the cleanup, seal/paint stage and then I need to come up with a design.
Smackdaddy, I also used your advice and made a bucking tool for my air hammer. Thank you , I'm sure it will come in handy soon.
Id like to figure out a way to create my design on the computer so I can play around with storage placement and get an idea what I'm looking at. What programs do you guys suggest or use ?
Bigwrench
Post by Bigwrench »
Wow I just realized it's been over a year since I posted !!! Several life situations have happened and also I'm a big procrastinator with too many projects and irons in the fire lol but there has been some progress, So I'll try and update over the next couple days !
Adding pictures as time allows.
Here is what I have to work with
Playing around with ideas
The hull has been stored upside down in the yard .
I decided to start working on the trailer first since this is where my skills are the strongest.
I stripped it down to just the frame, repaired some cracks where the slipper spring on one side has pushed through.
Installed some new wheels and tires
and drove it to a local media blaster who took it down to bare metal and refinished it in an industrial black that supposedly will outlast the trailer lol.
New wiring harness and lights
He also welded in some supports and straps around the slipper springs to stop them from breaking through again.
Tonight I decided to just work on the outside of the hull so we covered the trailer with old blankets and placed the hull on the trailer frame , bottom side up . Since my play money has dwindled some due to a couple fishing trips this fall I'm just roughing up the outside with a wire brush . My plan is to brush the entire outside , acid wash it and then take it to work to our body shop for final sealing, prep, priming and painting in one of our booths to bake it on good and thick. The outside will be a desert type camo. I also have a portable pressurized blasting tank and a couple different types of media I'm playing around with
I'm still going to media blast the entire inside of the hull (professionally) when the budget allows , having him blast the inside and the outside just isn't in the budget right now. I will be going back with aluminum plate decking and lots of compartments and plenty of foam. Gonna be a long process but I'm determined to see it through if it takes 5 years lol.
bonz_d
Post by bonz_d »
It's easy to understand how projects sometimes get pushed aside. I myself have 2 projects sitting here. The one I hope to finish first is the Sea Nymph Pike Attacker that I picked up this summer for a song and was supposed to be a quick turnaround.
So far yours is looking promising.. I'll keep a watch out for your progress!
1988 Alumacraft Classic 16, 50hp Johnson on a Shoreland'r trailer.
1984 Sea Nymph Pike Attacker, 30hp Johnson on old Gator tilt trailer
Welcome back bud!
Please use our Amazon Affiliate link. It costs you nothing and sends a few cents to the site.
Amazon Link!
Bigwrench
Post by Bigwrench »
I uploaded some pictures of progress but somehow they got out of order. Most likely because I'm using tapatalk. I'll try to organize them on the computer today , I may have to try and upload them one at a time until I figure out the issue.
JMichael
Post by JMichael »
Bigwrench wrote:I uploaded some pictures of progress but somehow they got out of order. Most likely because I'm using tapatalk. I'll try to organize them on the computer today , I may have to try and upload them one at a time until I figure out the issue.
If you upload your pics to one of the free hosting sites like photobucket/tinypic/etc then you can attach your pics with the img code in any order you like and there's no size restrictions when you do it that way.
Wyatt
6
Post by Wyatt »
Yea tapatalk can be a pain in the hind end sometimes. Can't wait to see more progress on this rig. Keep up the good work!
