1990 Bass Tracker Pro 17 interior rebuild
reward77
What started out as a project to replace a rotted out floor has turned into a complete rebuild of the interior of my 1990 Bass Tracker Pro 17. Lots of great info on this forum and I've already discovered many of the mistakes Tracker made assembling these boats such as the foam blocking proper drainage. I have the rear of the boat almost complete disassembled and was wondering if anyone has any advice on the pros/cons of adding some additional storage to the rear deck and then surrounding it with foam? I'd like to add something like Cabela's offers here:https://www.cabelas.com/product/Boa...ge/104378580.uts&WTz_l=undefined;cat104378580, but my understanding is that these are just the lids and not the actual boxes. So my questions:
1) Thoughts on adding storage on each side of the rear deck?
2) If a good choice, any recommendations on hatches/bins?
3) What foam should I use when replacing back corners? Same as new foam in floor?
Will post some picture of process thus far next.
Rob
Some pictures of progress thus far:
Foam blocking drainage channel:
Factory foam on one side of rear deck:
Foam surround vent and live well hoses:
