painting inside boat
joho5
Post by joho5 » 30 Mar 2015, 10:37
when you guys paint the interior of your alum boat, do you use a brush? Or spray?
thanks
Tinny's Dad
Post by Tinny's Dad » 30 Mar 2015, 12:31
2 years ago I did mine with a brush, worked out very well
Johnny
Post by Johnny » 30 Mar 2015, 12:51
depends on you - - - do you have the time to brush it on ?
How are your brush skills ? Have you ever painted anything before ?
How much area are you talking about ?? 10' Jon boat or 20 footer ???
Do you have a blank hull inside ? or already have flooring, carpet, seats, etc etc etc.
I have done all three.
brush when I have the time and it is small area.
roller it out on large areas, touch up with the brush.
quick n easy: Wagner Power Sprayer if you have one.
and believe it or not, I have used a pump-up garden sprayer !!!
Using latex paint, thin it down quite a bit, strain it through a fine mesh paint strainer.
Pump up and spray. Address the runs with a brush.
Seven Bucks at most hardware stores. 1-1/2 quart capacity.
If you prefer to use oil base paint, just throw it away after use.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
overboard
Post by overboard » 30 Mar 2015, 17:56
I did mine with a brush and roller; came out pretty good.
rickybobbybend
Post by rickybobbybend » 30 Mar 2015, 23:45
I have used brush and roller, as well as spray-on. Both worked fine for my purposes; brush better for larger areas and spray better for really tight places. One recommendation: avoid gloss finishes if you are concerned about surface imperfections or about it getting scuffed up in use.
RickyBobbyBend
Gregor 1244 Welded V, Evinrude 9.9
Modest Mods on Gregor 1244 V: http://www.tinboats.net/forum/viewtopic ... 21&t=24612
Post by BigTerp » 31 Mar 2015, 08:05
If you have an air compressor, an HVLP spray gun makes quick work of painting a boat. Also puts a nice even coat on. My buddy picked one up of Harbor Freight for less than $50 for a few projects he was working on and let me use it for my boat. Made the job simple.
http://www.harborfreight.com/2-pc-profe ... 61472.html
Ringo Steele
Post by Ringo Steele » 03 Apr 2015, 12:30
I used a HVLP sprayer for mine, since I already have a compressor. I have used a roller or a brush as well. Google "roll and tip" painting if you don't want to spray. You can get a pretty good finish this way, even on glossier finishes.
1971 Ouachita 16DSV, 15.5' semi-vee, 65" beam
1974 Johnson 15HP Sea Horse 15R74S
MinnKota Endura 50 trolling motor
1971 Cox trailer
My slow mod project... http://www.tinboats.net/forum/viewtopic ... sv#p301835
My gallery: http://www.tinboats.net/Gallery/thumbna ... ?album=369
