Poormans Boatright
I've been working on boat railings, flounder rigs, leaning posts, etc.... which all involve pipe fabrication, as some of you might know. Up until now, I have been using a pattern to mark or layout my "fishmouth", miters or saddles as some fabricators call em. I would then simply take my 4" grinder and cut away and form the "fishmouth" on the piping. I've used this method for years and I have it down pretty good. I can basically tell what the miter is gonna look like n grind it.
I bought one of these tubing/pipe notchers from Eastwood, I have had this tool for at least 2 years and have never used it. Well today we were fabing up a duck hunters rack for a Polaris Ranger, and I decided to try this thing out. I found it pretty easy to use, all ya have to do is square the mounting base of it with the main frame and bolt it to your drill press stand, line up the shaft to your chuck on the drill press and presto, ya got a instant notcher. Simply install the tubing or pipe into the tools holder and with the proper size hole saw it makes perfect "fishmouth" cuts for your project. Check out the pics.
