where to buy alumacraft olive drab green color
amk
texas
I need to repaint some sections of my boat any one know where I can get some either oem or close to exact match spray paint olive drab green.
So far the closest I've found without going to a dealer has been Rustoleum deep forest green. Its pretty close. I used it to paint my trolling motor mount. It was available in the paint dept at Walmart.
https://www.walmart.com/ip/Rust-Oleum-Specialty-Camouflage-Aerosol-Deep-Forest-Green/19395289
looks pretty good doubt my wal mart carries it knowing them but ill check it out.
I found it on the bottom shelf its marketed as a "special" camo paint. There were like 4 different colors all with the picture of the boat.
Found some painted my boat. I washed it and wiped clean it looks good but scratches right off the aluminum. I guess I need some kind of primer. It will do for now but eventually I'll sand it down and prime it and use a paint gun to do a better job.
If there is anything you can take off the boat to bring to home depot, they can do an exact color match. You can then touch up with a brush.
