Classic25
Got a leftover 13 Lowe 1648T which has a factory aluminum floor. Lowe screwed up the dealer order so they gave me the boat priced without the floor! Although the front also has the floor I wanted it raised up a bit and leveled off so I built a carpeted deck and also mounted the seat to it so its much stronger than mounting on center bench. Im waiting for my bow trolling motor mount to come from Lowe. Got a 50lb Minn Kota powerdrive that Ill mount up front. I also got a 20x20 piece of 1/4 inch aluminum cut which will be riveted to the rear bench. Ill then mount the rear seat to that and that piece of aluminum should give it plenty of strength. No gas engine for now as theres only a couple of 9.9 lakes in South Jersey where I can use em. Cant wait to get out there!
Dave
Dave
