CMOS
Howdy All,
Below is a pic of my current rig, with a short shaft 1966 Johnson 9.5. It does sit a bit low on the transom but still gets very good performance.
Recently I found a good deal ($200!) for a 1982 Johnson LONG Shaft 15 HP. I'm currently working on getting it running. I'm faced with making a decision to either convert to a short shaft ($170 for driveshaft and ~$25 for a shift rod) OR - use a TH Marine "Mini-Jacker" transom plate to get it to the correct level. I'm leaning towards the jack plate due to the fact that my current 9.5 short shaft is a bit low - the 15 HP will also be.
My one concern with the Mini-Jacker is, will it put the tiller handle up too high in an uncomfortable position?
I also like the fact that I would get about 4" of transom offset which would move the tiller handle back a bit.
Keep in mind that one of the reasons I got the 15 HP is that at some point I will want to buy and restore a 16-foot tinner.
Any opinions or thoughts on me leaning towards the Mini-Jacker?
Thanks,
CMOS
Thanks,
CMOS
