Alumacraft 1442 NCS front deck
-CN-
Mauston, WI
If I were to cut into the stock front deck to create a storage compartment, what would I find in there? Solid foam?
And how would I go about cutting it? I think I just want to cut a square hole in from the top about 36" x 24".
I will be adding foam under the floor.
I've done this on both my flat bottoms and loved it. I'd take a look at your deck first though and find if there are any supports running under the deck. Find those and then decide on measurements. You can cut through them though, just be ready to add some aluminum angle to replace the support.
The foam will probably be the white stuff.
