Jet jon is it legal to build
Bx10
jarretsville md
I just recently found a boat to buy to a 1448 aw flat bottom already had a jet ski laying around which is a suzuki 3 cylinder 1000 motor. I'm currently just waiting on my spoolmate gun. but been doing a lot the of reading about overpowering the rating on the capacity plate. I just want to make sure when i build this boat it isnt going to be some kind of hassle with that. Any input would be greatly appreciated
I checked this out before building mine. I even called the coast guard, as I got bad info from my DNR guy.
After you modify the boat, you should have it re-registered as a 'Homemade'. You can list it as an inboard with XX hp.
There are no HP limitations with an inboard.
The Coast guard does not require any inspection on a homemade boat.
That said, it is best to conform to the USGC regulations, search for 'boat builders' guide, it's long but only parts of it are relevant.
Also, i had no problem getting insurance after the boat was properly reregistered.
I live in maryland Im pretty sure there is a law about overpower ordeal. So changing it to homemade boat and getting a new plate is best way to cover your butt
