Added a step...with Anchor storage
Houston, TX & Crossville, TN
My new front deck is just high enough to make this old body strain getting up and down, especially with a fish on.
I used an old battery case (to keep the water contained), and built a plywood frame around it.
Some 3/4 plywood for the step and Voila! an improvement.
My rig has an extra battery box. It big enough to fit a small anchor and the spare prop. Is that diamond plate aluminum or some kind of rubber. It looks just right!
It is a Harbor Freight rubber step. They come one foot square and also some long skinny pieces. It has self stick glue on the back. Good traction.
https://m.harborfreight.com/self-adhesive-rubber-safety-step-tread-98856.html?utm_referrer=direct%2Fnot%20provided
That's a good deal.
I've been thinking of adding a step to the bow deck on my 1860 that could hold a 12/15 gal fuel tank and 2 batteries for a 24 v bow mount trolling motor I also want to add. Nice work on your step.
richg99 said:
If you are going to have both fuel and batteries in the same closed space, I'd be certain that it was very well ventilated.
..For sure, I'm planning to use a below deck type tank w a remote vent along w vents on the box.
wish i would have thought of that when i had my boat. i used to step on on the plastic battery box all the time, each time i thought i am going to look like and idiot if this thing breaks and i fall at the ramp.
" i used to step on on the plastic battery box all the time, each time i thought i am going to look like an idiot if this thing breaks and i fall at the ramp."
That was what I was afraid of, and why I built the plywood outer frame and top-step.
