I recently bought a tracker grizzly 1648 and will be putting vinyl down as the flooring. I'm also extending the back deck about 2' going toward the bow as well as hatches in the stern where the batteries/gas normally would go. I plan on making a template with craft paper for my cuts but my question is, how many sections should I split it up in? I want to cover decks, floor and sidewalls. Do I do front deck as one piece, back deck as another piece and floor as a 3rd piece etc? I'll be the only one doing it so won't have extra hands so am nervous about bigger pieces. Also, there are 3 holes in the floor about 2/3s back for water to drain. Would I be ok leaving those open still? With the marine vinyl, would the water seep through and make it to the drainage or does it mostly stay on surface to roll its way to the drain holes on the surface? Thanks for any input
