Push pole holders
Fishfreek
TinBoats Supporter
East Central Florida
I picked up a good used push pole to use on the flats here is Central Florida but now I am looking for a way to mount holders to my tinny.
Here is a picture of the gunnel area. I am thinking that I may need to install several blocks running down the inside to mount the holders to. Any suggestions or pics of yours would be a bonus.
It seems that the gunwale design on those boats doesn't give you many options without fabbing and drilling. I was thinking some sort of clamp - on base and mount like this...
Or what about having 2 small pieces of aluminum angle welded to the top of the gunwale to create a flat spot to mount a standard push pole holder. One near the bow, and one near the stern. Maybe one midships also. The you could use something like this...
Or this...
2015 Tracker Grizzly 1448 MVX
1996 Evinrude 25hp 3 cylinder looper
That is actually used on a gps rover rod. You could probably get those from a survey supply company, but they would be stupid expensive. Maybe you could have something similar made somewhere?
