870 ExpressMag
- Joined
- Jun 16, 2012
- Messages
- 19
- Reaction score
- 0
So I've got a 15ft Meyers, old enough to not have a data plate, 2 piece hull joined in bottom center and cast aluminum corner gussets. Used to be console steer but controls were taken out and converted to tiller well before I owned it.
I have owned since 2012 and am finally tired of vacuuming the little foam balls out of the boat after every use. When I got it the bow compartment smelled of mice so I kinda figured what had happened. Anyways I finally decided to take the bow apart and replace the foam. It is full of just pieces of regular styrofoam, is this likely original? It appeared as though I was the first to remove the bow cover but not sure.
Anyways I didn't start this project like many of you with modifications in mind, however since I am this far I am now wondering if I could fix a few annoyances I have with the boat. The guy that sits up front is always crowded with stuff around his feet due to the design of the boat, I was wondering if any of you had any ideas on how I could make a specific anchor compartment somehow so it's not rolling around on the floor by their feet.
I do kinda have a weight issue in the back as there is me(200lbs), the 18hp evinrude fastwin, deep cycle/starting battery, and a 55lb thrust minn Kota. I usually put the 6gal tank either just forward or just aft of the center seat. So I thought of trying to move battery up forward but don't want the boat to nose dive either. My passenger rants from dad(200#), to my best friend (320#).
