TILLER EXTENSION FOR A 40 HP MERC
HOOSIERGRIZZ
I have an 18' Lowe Roughneck with a 40 hp tiller. I'd like to extend the tiller handle around 2' so I can steer while standing (at low speeds) so I can watch for obstructions better. Most of the ones I'm seeing look pretty cheap and say they are for engines under 15 hp.
If anyone's had the same problem, can you give me a reconmendation? Thanks for your time.
Started out with this:
https://www.ironwoodpacific.com/store/products/467/HelmsMate-Outboard-Tiller-Extension-Handles
Upgraded to this:
https://shop.carbonmarine.com/product.sc?productId=1
More expensive, more stable, more durable, more better...
2015 Tracker Grizzly 1448 MVX
1996 Evinrude 25hp 3 cylinder looper
i made one out of pvc. used a piece of 1-1/2 in, cut 4 slots in it.fitted a 1 in coupling in it by sanding and then a 1 in piece into that. 2 stainless hose clamps and some non-slip tape. spray paint. ill try to post a pic. easy
