How do I fasten 2x4 to me middle seat
Wallyrosie
Floor is all mocked up I have just one question that I needed an answers to!
How do I fasten the 2x4 to my middle seat. What works the best I've got Sheetrock toggles around the house here I could use.. Thank you for your help
On way would be to pop rivet or use blind rivet nuts to fasten an aluminum angle support under the 2x4 for it to rest on. You could then screw into the 2x4 through the angle support to hold the frraming in place.
Sent from my ASUS Transformer Pad TF300T using Tapatalk
I'd just cut some short pieces of aluminum angle to make some L brackets and rivet/screw those where ever you needed to attach it at.
How about a 2x4 going from under the 2x4 to the floor. Then you would need minimal attachement to the bench itself.
If these folks don't have it . . . you don't need it. :D
https://www.pemnet.com/fastening-products/pem-self-clinching-fasteners-new/
