1971 Valco Refurbish
erick.mckague
Just picked up a 1971 Valco hawk. when I got her into the water there appears to be a small leak in the seam of the hull. I'm sure there are some rivets that are leaking as well, but that was my main leak. I had the boat on the water for about 4 hours and took on approx. 3 gal of water. My question is what is the best way to go about sealing the leaks. Second problem is that the boat was sitting for quite awhile on its top. Due to this it has dents in the aluminum below and above the waterline. I've read not to apply heat to remove the dents and then other say its ok as long as you stay well below melting. Ive tried the rubber mallet and support and these things are budging. What are me best options.
Thanks
you said: "I've tried the rubber mallet and support and these things are budging"
Typo? did you mean there are NOT budging?
I have had somewhat good success with the automotive
steel blocks and dollys with various size TinSmith's hammers.
Put away the rubber mallet - - - go to the solid nylon, nylon faced
Dead Blow or rolled leather and wood mallets for better results.
Some are more aggressive than others, so there is a learning curve.
I personally do not recommend the round face carpenter hammers.
At Harbor Freight, you can pick up some nice metalworking hammers for cheap.
For cosmetics, IF you are going to paint it afterwards, smear some
Bondo on it, sand, prime and paint it.
Stay far far away from those "as seen on TV" spray seals !!!!
PHOTOS of your issues would help quite a bit.
The most popular suggestion is: while the boat is on the trailer,
with the wheels blocked securely, fill the boat with a few inches
(6-10") of water to observe and mark the leaks - - - take photos - - -
then, you can more accurately address the leakers.
oh, and WELCOME Eric to the Wonderful World of Tin !!
Tin and metal working is very enjoyable and relaxing, once you get the hang of it.
