Quick transome replacement ques
oldude
Post by oldude » 25 Jun 2016, 21:54
I searched the site and went thru 41 pages on this subject. I plan on using 3 pieces of 3/8" bcx plywood sandwiched together to make the 1 1/8" thick replacement. I plan on using titebond III to glue them together. I will also be using the old time method to seal it.
My question is: do I seal the sides of plywood that will be glued together or just the outside (front and back) pieces and edges? I didn't find a definite answer to this on my search.
lckstckn2smknbrls
Post by lckstckn2smknbrls » 25 Jun 2016, 22:25
Glue the plywood together first, then cut out the shape you need, then do the old timers.
oldude
Post by oldude » 25 Jun 2016, 22:39
lckstckn2smknbrls; thanks
momule
Post by momule » 26 Jun 2016, 17:46
oldude wrote:I searched the site and went thru 41 pages on this subject. I plan on using 3 pieces of 3/8" bcx plywood sandwiched together to make the 1 1/8" thick replacement. I plan on using titebond III to glue them together. I will also be using the old time method to seal it.
What reason would you have to not seal the edges of the plywood? Sealing the edges seems like a no brainer to me.
Current Craft: Lowe 1448 Big Jon, all aluminum transom, decks, console w/ Yamaha 40/30.
Previous: Cajun 185 w/150 Johnson, Tracker TX17 w/60 Mariner, 24' Pontoon w/60 Merc, Ozark Tri Hull F/S w/120 Evinrude, 16' Lowe Olympic Jon w/ 40 Mariner, 12' Lowe w/ 4.5 Merc, Coleman Scanoe, Ouachita alum canoe
oldude
Post by oldude » 26 Jun 2016, 18:44
I'm going to seal the edges. I just didn't know if i had to seal the sides that are glued together.
CedarRiverScooter
Post by CedarRiverScooter » 26 Jun 2016, 22:48
Wood glue won't soak into the wood fibers if it is sealed beforehand.
oldude
Post by oldude » 27 Jun 2016, 08:06
That's what i was thinking too. I just wanted to be sure. This is a 14' jon boat that "lives" in a pond. Not my boat, but the guy who owns the pond lets me use it. The transom was so bad even my trolling motor would flex it. The clamps on my troller just crushed the wood. I offered to fix it for him on my dime. The cap was also cracked on both ends so i had those welded.
