It is currently 25 Apr 2019, 06:48
BoatCoversDirect
 Page 1 of 2 [ 30 posts ]  Go to page 1, 2  Next
 Post subject: patio umbrellas
PostPosted: 29 Jun 2016, 08:46
has anyone used a patio umbrella for shade? i am thinking bout using my seay pole as a support, sliding a piece of pvc over it and inserting a patio umbrella in it. the pvc would have to be big enough to fit my seat post and umbrella, maybe 3 in dia. opinions/
PostPosted: 29 Jun 2016, 10:14
This guy totally beat you to it
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
PostPosted: 29 Jun 2016, 10:16
http://www.basspro.com/Reel-Shade-Umbre ... uct/45229/
my build 1976 14ft Meyers V hull
viewtopic.php?f=21&t=40127
PostPosted: 30 Jun 2016, 16:24
I used Scotty rocket launcher type to hold umbrellas and patio umbrellas. They work great and are removable.
PostPosted: 30 Jun 2016, 22:09
Yeah, I'll stick my beach umbrella in a rod holder, but I personally don't see the need for the size & weight of a patio umbrella. But I also have a bimini top on the 16' skiff, sized so I can stand under it.
#1) 1st tin rebuild, 18' Lund viewtopic.php?f=21&t=36583
#3) 16' V-tin rebuild viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins viewtopic.php?f=3&t=37548
Online
PostPosted: 01 Jul 2016, 00:24
Yes my dad lays one on its side and anchors off so the sun is to his back. It works ok and he uses the patio seat cushion for the bench seat in the boat. Anything to be comfortable and get a little more time on the water.
"Fish On!"
PostPosted: 02 Jul 2016, 06:23
RiverLife wrote:
and he uses the patio seat cushion for the bench seat in the boat..
This never occurred to me and I have a couple in storage!
Thanks!
Alumacraft 1236
Minn Kota Endura C2 30
PostPosted: 02 Jul 2016, 07:15
Seat cushions .... use patio seat cushions on boat.......
"This never occurred to me and I have a couple in storage! "
Ha Ha I also have a couple in storage...of course, storage is 900 miles away in Houston. Darn.... richg99
Always told my kids....If.... "Somebody ought to do something" comes up....remember...you are "SOMEBODY" !!
PostPosted: 04 Jul 2016, 08:44
I used 4 pvc Ts and 4 pieces of pipe to make a big square, one side slips over my seat pedistal and the other holds the umbrella out far enough to allow my seat to swivel w/o hitting the umbrella pole. I have a cheap, tilting umbrella and it works pretty good to keep the sun off. I can also sit in the seat and cast/fish easily.
 Post subject: Re: patio umbrellas
PostPosted: 01 Sep 2016, 22:02
I've used a patio umbrella in my last boat. I had to make an adapter sleeve to make the pole fit my vertical rod holder. I don't mind sitting in the sun. But my wife and son don't like to bake. So, I bring it for them. Works good and I only use it when we are not under way.
Sincerely,
jbird68
2006 Alumacraft Navigator 165 CS (Crappie Slayer)
2006 Mercury 90 HP Optimax
1979 Evinrude 6 HP Long Shaft Kicker (To be installed)
Minn-Kota Terrova 24V 80# Thrust Trolling Motor w/ I-pilot
2006 Dodge Durango SLT (Bright Blue) 4.7L Next Generation V8
PostPosted: 01 Sep 2016, 22:41
How about some pictures?
A couple of the med's I'm on say to avoid direct
sunlight. The last sunny fishin trip I went on, I was
sick all the next day.
And it wasn't from adult beverages, Most of the med's
advise to avoid alcohol. [-X
So I had to give that up :x :cry:
I don't want to give up fishing :!: :!:
Steve A W
Professionals build the Titanic.
Amateurs built the Ark!
PostPosted: 02 Sep 2016, 17:44
Steve - I got two beach umbrellas at Bass Pro.
they are a bit bigger than the personal umbrella
and a lot smaller than the standard patio style.
It has an adjustable elbow to tilt in any position.
You could probably rig a 1-1/4" PVC pipe with straps
to hold it firmly in place. I would not trust the standard
pole holders to hold it..... the more beefier you can make
the clamp/straps the more secure it will be. Lanyard it
to something that will not move in case it gets blown out
of the holder - - - "case by case" when installing.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 03 Sep 2016, 08:07
Just DON'T forget to remove it before you take off from your fishing spot. I was idling from one spot to another just on the other side of a bridge. OOOPS and right in front of a riverfront restaurant. oh well at least they got a good show. I probably should have charged admission.
Fish fear me
Women love me
But I sit here all alone eating peanut butter sandwiches
PostPosted: 03 Sep 2016, 14:58
Sounds like a Snap Chain would be in order. Do NOT attach it with a bungee....and then drive off....WHACK!!!!!
PostPosted: 04 Sep 2016, 20:46
Use a PVC frame and a cheap tarp, gives as much or as little coverage as you want.
Users browsing this forum: Colorado1135 and 46 guests
cron
