It is currently 18 Apr 2019, 16:56
FishonFabrications
 Page 1 of 1 [ 5 posts ]
PostPosted: 04 Jul 2016, 13:00
Selected almond color for interior. Brush painted the seats and brackets. First coat of spray paint on the new aluminum panels for supporting the foam under the seats.
PostPosted: 11 Jul 2016, 18:30
Finally time to re install the original foam under the seats. I used automotive plastic fasteners to hold the shape. With the panels in place I will add Secure Set 2 part foam to glue the old foam in place and give the face panels some support.
PostPosted: 11 Jul 2016, 18:52
looks good bud
I am in the automotive industry, we call those fasteners Christmas trees for obvious reasons lol
my build 1976 14ft Meyers V hull
viewtopic.php?f=21&t=40127
PostPosted: 04 Aug 2016, 19:00
Foaming was fun and good to have nearly done. Started today on the aluminum plates to fix the hole in the stern left by the transducer mounting bracket.
PostPosted: 29 Aug 2016, 07:47
Painted the inside with 2 coats of oil based Rustoleum. A little bit of mineral spirits really helps get rid of brush strokes. The holes and corrosion from the stainless steel transducer bracket were wire brushed; covered with JB Weld, then clamped between two 3"x4"x1/4" 6061 aluminum, countersunk 10-32 SS machine screws hold the plates together. When the transducer mount is put back on there will be some substantial material to drill and tap.
Users browsing this forum: Google [Bot], Google Adsense [Bot], jasm2, Jebber, tintweeker and 63 guests
SliderG5
