It is currently 26 Mar 2019, 01:52
SwampRunner
 Page 1 of 1 [ 7 posts ]
 Post subject: Weight balance.
PostPosted: 07 Jul 2016, 23:22
I got a 73 Sears 12 footer last summer. Small, but gets the job done. Just put it back in the water at the lake house. Had it out today by myself and that thing is a bit tough to maneuver with so little weight in the front. Usually out with my 9 year old. He gives it enough to help steer. Should I move the gas tank up? Its only a 3 gallon. My motor is only a 5 hp. , but the lake is only three miles. What are my options?
PostPosted: 07 Jul 2016, 23:43
I usually use either commercial bags of sand, sold for winter traction or perhaps for gardening. Also, just really durable commerical bags...like 50lb dog food bags, which are water proof and heavy, filled with gravel or/and sand.
I've got about 80 lbs up front in my Alumacraft model RB, a 12ft boat, with a 70 lb 10 horse motor, the gas can, and me in the back. Adjust as needed.
Have fun.
Kis
Enjoy every sandwich
1955 Alumacraft Model A
http://www.tinboats.net/forum/viewtopic ... 08&start=0
1959 Alumacraft Model F
http://www.tinboats.net/forum/viewtopic.php?f=3&t=25386
1980 Alumacraft Model F7, 1955-56? Johnson 10hp
viewtopic.php?f=4&t=35326
1956 Alumacraft Model RB
http://www.tinboats.net/forum/viewtopic.php?f=3&t=39249
PostPosted: 08 Jul 2016, 02:45
Can you fix, semi-permanently, a Five Gallon bucket up front? Filled with water ( 8 lbs per gallon) that would add 40 lbs..
At least you can vary the amount by how much water you add. Be certain that it is well attached, and the cover is locked down, too. You don't want a lot of sloshing around.
A handy guy could add a spigot on the bottom that would allow you to drain the water out when necessary.
Always told my kids....If.... "Somebody ought to do something" comes up....remember...you are "SOMEBODY" !!
PostPosted: 08 Jul 2016, 15:55
In my light jon boat I put a deep cycle battery up front.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
PostPosted: 08 Jul 2016, 16:08
"Water ballast" is as old as boats and is even used on big ships today!
I usually move the tank or would do the bucket trick Rich mentions. Simple is good ... as trim is crucial on small boats!
#1) 1st tin rebuild, 18' Lund viewtopic.php?f=21&t=36583
#3) 16' V-tin rebuild viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins viewtopic.php?f=3&t=37548
PostPosted: 09 Jul 2016, 10:28
Some good, experienced, opinions offered here.
I don't argue, but my choice for the sand was the ability to shape it over on one side of the bow and have it stay there, and the stability of the weight. When I tried--first gallon jugs, then a 5 gallon bucket--the empty jugs were somehow always in the way in the car, and the bigger container wanted to be centered in the middle of the semi-v.
Whatever you choose, best wishes and be safe.
Kis
PostPosted: 09 Jul 2016, 10:56
This. I don't ADD weight just for ballast if I can help it. I try to relocate existing weight . Keep in mind our little boats are very weight sensitive so I try not to add any weight I don't need.
Users browsing this forum: Blue Dawg, Google [Bot], Google Adsense [Bot] and 86 guests
