It is currently 19 Apr 2019, 06:35
 Page 1 of 1 [ 8 posts ]
 Post subject: Jon Boat Paint
PostPosted: 18 Jul 2016, 22:40
I am going to start prepping my boat for paint this weekend.
What is the proper paint to use? I want to paint the boat the "Duck Boat" color.
I was going to use this brand paint from Home Depot (Duralux marine paint)
http://www.homedepot.com/p/Duralux-Mari ... 128261-_-N
But, read on the reviews that it scratches easily? Also read color is more a military vehicle desert tan color?
Have any of you used this brand?
What brand would you recommend?
Also, the paint I was looking at says it is a "Durable, water resistant alkyd enamel"... Is a alkyd enamel the proper paint I should be using?
Thanks again...
PostPosted: 18 Jul 2016, 23:05
Parker duck boat paint. Cabelas carries it.
PostPosted: 19 Jul 2016, 07:00
I used Duralux "dead grass green" on mine, that particular color is more of a tan than green, that may have been the color you mentioned that looks like a desert tan, I like it you may not.
I'm happy with it, I would think any paint will scratch, and don't know if a hardener could be added to possibly make it more durable.
PostPosted: 19 Jul 2016, 19:41
I used Duralux Marine Paint Model # M736-1 1-gal. Aluminum Boat Green Marine Enamel from Home Depot on my boat. The only issues I have had with it is where my straps hold the boat to the trailer, it wears the paint to bare aluminum. I figure any paint would wear if it was under straps tho.
If you chose this paint, I would suggest not using a cheap roller, it will eat it away. I have a thread with my boat and shows the paint job.
Let us know what you went with and how it worked for you.
1979 MirroCraft F4604
1967 Johnson MQ13 9.5 Hp
1974 Evinrude 25452M 25 Hp
Life member of the LGOPPs
 Post subject: Re: Jon Boat Paint
PostPosted: 19 Jul 2016, 20:00
Thanks for sharing this. I really like that color and instead of parker paint I'm going with this.
PostPosted: 19 Jul 2016, 21:14
I will be spraying the paint with my spray gun... Do you need to thin the Duralux paint?
If so, what thinner is recommended?
PostPosted: 19 Jul 2016, 23:10
Read, Understand and Follow the instructions on the label
of any products you may use........
Instructions and Safety Procedures are there for a reason.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 30 Jul 2016, 18:40
I am not sure about a thinner for spraying, I just rolled mine. Still came out decent.
Users browsing this forum: Google [Bot] and 86 guests
TheRescueStep
