It is currently 24 Mar 2019, 06:42
SwampRunner
 Page 2 of 2 [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rivet size
PostPosted: 03 Aug 2016, 21:02
Awesome! Thank you!! My aluminum should be in tomorrow so ill get er started!!
Sent from Mossy Oak Swamp Bottom
Florida Outdoors Hunting & Fishing Forums
Http://www.FOHAF.com
 Post subject: Rivet size
PostPosted: 04 Aug 2016, 12:06
I didn't have good luck with those off the shelf rivets with the aluminum mandrels - they often snap before they really pull tight. I ordered aluminum rivets with steel mandrels and found them to be much easier to get tight. I believe the steel mandrels were also thinner than the aluminum for the same size (3/16) rivet, though I don't know if that resulted in thicker aluminum walls in the rivets or not.
http://rivetsonline.com/rivets-en/blind ... ndrel.html
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
PostPosted: 04 Aug 2016, 13:49
Also at every location you are going to put one rivet put 2 it will keep the 2 pieces of aluminum from pivoting around the one rivet.
PostPosted: 04 Aug 2016, 22:02
I needed to pop two 1/4 inch diameter rivets recently and I bought that same gun with a 20 percent coupon. Works great........Good tool to own if your a tin boater.
My Duranautic 16 Side Console
viewtopic.php?f=3&t=41658
My Duranautic 13 (sold)
viewtopic.php?f=21&t=37700
DN13 on the run (video)
http://vid1346.photobucket.com/albums/p ... 3ciqmm.mp4
PostPosted: 05 Aug 2016, 16:51
Thx for the info!!
PostPosted: 11 Aug 2016, 13:30
Ready to rock! Now just gotta get time to start this project!
PostPosted: 11 Aug 2016, 14:05
Got enough drill bits????
Those are the aluminum/aluminum rivets I was speaking of earlier.
PostPosted: 11 Aug 2016, 14:47
I find that by "sneaking up on the torque" (actually breaking point) on those aluminum body/aluminum mandrel rivets, rather than setting them FAST ... that one can get them pretty darn tight. They do not replace solid rivets by any means, but should be fine for sub-structure installs. FYI, on that Aircraft Spruce website, there's some guidance on the number of rivets per inch to hold the material used as needed for the designed sheer stress rating.
#1) 1st tin rebuild, 18' Lund viewtopic.php?f=21&t=36583
#3) 16' V-tin rebuild viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins viewtopic.php?f=3&t=37548
PostPosted: 11 Aug 2016, 14:55
yup got the rivets from tractor supply!! Figure if i break a drill bit id be pissed to go buy one cause i live in the woods and have to "travel into town" just to get anything lol.
Then if i break that many bits i rekon ill be pretty pissed off lol
You mean going nice and slow before it pops?
PostPosted: 11 Aug 2016, 15:34
I was using the squeeze riveter - not the two handed tool, perhaps that influenced my results.
PostPosted: 11 Aug 2016, 15:43
I seem to get the best results when I tighten the rivet just snug first, then open the gun and re-grip for the final slow pull. Don't be in a hurry. Going slow helps get them tight as possible.
PostPosted: 11 Aug 2016, 16:09
THIS ... snug, then re-gripping or 'choking up on it' a couple times! Maybe its keeping the toolhead only a 1/16" or so from the pull that makes it tighter, i.e., less shaft under tension? But I find it works!
#4 Procraft SV14
Users browsing this forum: Mzzy and 86 guests
akmccallumco
