It is currently 24 Mar 2019, 06:44
mud-skipper
 Page 1 of 1 [ 6 posts ]
PostPosted: 02 Aug 2016, 18:33
Help! Trying to Repair Cracked Aluminum on V-bottom hull Duratech rowboat. The 12 foot Veeline Utility boat has a eight inch long crack along the bottom front of the "V". Similar to boat pictured. What is the best material to repair the Aluminum? Thank you.
PostPosted: 02 Aug 2016, 18:52
Mig or Tig welding.
PostPosted: 02 Aug 2016, 23:43
This item has been discussed many, many times. If you start squeezing junk into the orifice, the inevitable welding is going to cost you many times more than leaving it alone.
Do it right, do it first. Go have it welded. IMHO.
Always told my kids....If.... "Somebody ought to do something" comes up....remember...you are "SOMEBODY" !!
PostPosted: 03 Aug 2016, 04:57
Have it TIG welded by an experienced aluminum welder.
PostPosted: 03 Aug 2016, 07:27
I will have to agree with all above on this one. Get it done by a welder and you will probably never have to deal with it again.
PostPosted: 03 Aug 2016, 23:40
yep get it welded,,,, own a weld shop,,,,if ya was to bring it in to our shop to have it welded, would probably charge our minimum charge of $30 if it were all cleaned up and ready to weld,, best to drill a small 3/16 hole on each end of the crack to help stop the crack,,,, do the prep work your self and save your self some money
"YoBud"--------Dale Miller
Users browsing this forum: Bing [Bot], Mzzy and 86 guests
BoatCoversDirect
