It is currently 25 Apr 2019, 06:01
FishonFabrications
 Page 1 of 1 [ 13 posts ]
PostPosted: 04 Aug 2016, 13:06
I recently got a 17ft aluminum canoe and after taking it out for an hr or so my butt was numb and uncomfortable. I have some boat swivel seat seats that I was thinking about mounting to the canoe seats, would this be a bad idea? I couldnt find any pics on Google of anyone doing it to an aluminum canoe, and I was mainly worried about the raised center of gravity. But at most I will be sitting 4 to 6" higher. Do you guys think it will work out ok?
PostPosted: 04 Aug 2016, 13:39
It's been awhile for me, but the actual swivel seats available always took up too much room to really swivel side-to-side in the canoe. I was most often looking for lower back support, and I know there are several options out there, including a "sling back" cushion that hooked on the front of the seat and allowed the person to lean back into it. I didn't find them all that comfortable.
The most practicable option for extended cruising for me was just a plain old boat cushion.
Raising your center of gravity in a tippy boat is rarely a good idea, but some canoes are quite wide and may still be fairly stable.
The light-weight "racing" canoes have butt-holding seats, curved to fit your bottom. You can often find these sold separately. They are not cushioned, however.
If you paddle alone, consider sitting in the front seat, facing the stern. This gives you more stability and control, you are less likely to have the bow swing, or become a sail when the winds pick up.
Be safe, have fun.
Kis
Enjoy every sandwich
1955 Alumacraft Model A
http://www.tinboats.net/forum/viewtopic ... 08&start=0
1959 Alumacraft Model F
http://www.tinboats.net/forum/viewtopic.php?f=3&t=25386
1980 Alumacraft Model F7, 1955-56? Johnson 10hp
viewtopic.php?f=4&t=35326
1956 Alumacraft Model RB
http://www.tinboats.net/forum/viewtopic.php?f=3&t=39249
PostPosted: 04 Aug 2016, 15:19
That depends on how tippy it is. If it was pretty stable when you took it out while sitting in the seat you may be able to raise the height a little. If it was precarious trying to keep it from tipping over, no. The higher you go the more it will want to tip. You may have to experiment with it to get it to your liking. It just takes trial and error.
I bought a 12' canoe over thirty years ago from Sears without ever having been in one before and I had to take the seats out because it would tip over in instant at the slightest little wave or ripple. You have to paddle kneeling down to keep it upright. I still have it and I am pretty much an expert now at keeping the right side up but I still do not think I could put seats in it. I even fish for big catfish out of it now and have no problems.
Online
PostPosted: 04 Aug 2016, 16:58
Might consider one of those "butt" seats bass guys use on the tall seat posts, they look similar to a wide bicycle seat.
http://www.academy.com/webapp/wcs/store ... Type%5EPLA
Just a suggestion, you would probably have to install a post plate in the original seat, or figure out a way to keep it from moving too much on you while paddling, etc.
PostPosted: 04 Aug 2016, 18:51
Take your cell phone and wallet out of your pocket. lol ;-)
Jonah
www.RiverBottomOutdoors.com
Facebook
https://www.facebook.com/RiverBottomOutdoors
My Boats:
1656 CCJ http://www.tinboats.net/forum/viewtopic.php?f=21&t=29361
1448 MV http://www.tinboats.net/forum/viewtopic.php?f=21&t=15412
PostPosted: 04 Aug 2016, 19:02
The canoe is 17ft long and when I took it out last weekend I thought it was pretty stable. I weight 320lbs and my friend weighs 260lbs, he stood up multiple times to stretch. But I went ahead and mounted the seats and plan to take it out tomorrow afternoon. I will report back on the stability.
PostPosted: 04 Aug 2016, 19:17
Be safe, have fun.
I mainly put the swivel seats in because I had them on hand and they are comfy. Hope they live up to it lol.
Yea lol, I got a dry bag and plan to wear my life vest.
PostPosted: 04 Aug 2016, 19:36
Looks good.
PostPosted: 04 Aug 2016, 20:41
Looks good to me. Not as high as I imagined it.
Jonah
Facebook
My Boats:
PostPosted: 05 Aug 2016, 04:23
If your friend stood up in the canoe it should be stable enough to mount the seats with no problem.
Online
PostPosted: 05 Aug 2016, 22:35
Went out for about 3 or 4 hrs and my butt was compy. It was a little more tipsy but not much, out riggers would be appreciated though lol.
PostPosted: 05 Aug 2016, 22:45
I have boat seats in my 17' Coleman. I took the original seats out and fabricated some new braces that lowered the seats to keep the center of gravity low. Makes a huge difference
Sent from my XT1080 using Tapatalk
1972 Smoker Craft
Shorelandr trailer
1955 Evinrude 15hp
PostPosted: 06 Aug 2016, 08:43
That's two big guys in one canoe.
Everything said here is true. The higher you go, the less stable you will be. Period.
My prior experiences with canoes were always fairly positive, other than the canoe catching the wind just when I was trying cast into some fishy looking spot.
Except when I had another person in the canoe with me. Then, it was "trouble city". They'd lean Left, and I'd try to counter their moving weight..and the d$#@% would rock back and forth. We never flipped it, but we sure caused my blood pressure to rise a lot.
Not for me, but, I am old and clumsy. I'll stick to SOT kayaks, thank you.. richg99
Always told my kids....If.... "Somebody ought to do something" comes up....remember...you are "SOMEBODY" !!
Users browsing this forum: No registered users and 44 guests
cron
FishonFabrications
