It is currently 21 Mar 2019, 16:33
SwampRunner
 Page 1 of 1 [ 2 posts ]
 Post subject: Floor Plans
PostPosted: 21 Aug 2016, 15:35
Picked up a lund 14'. Has the "U" bench at the back then 2 more benches. This is going to be a winter project for me so i am looking at what others have done for floor plans. i was thinking of taking a bench out, however theyre riveted into the boat and do feel like doing rivet work. Thank you in advance.
PostPosted: 22 Aug 2016, 13:38
Welcome to our Bayou !!
your statement is a little confusing - - -
"they're riveted into the boat and do feel like doing rivet work"
do you mean you don't feel like doing rivet work ?
if you are going to remove anything riveted to an aluminum structure,
you must do something with the holes - - - replace with flat rivets, weld, or nuts n bolts.
I repaired several holes in the bottom of my '59 Crestliner using only aluminum
disks cut out of flashing material or soda cans and epoxy. Make a small dimple with
a ball peen hammer, sand down to bare metal, cut a disk a bit larger than the hole,
and epoxy into place..... sand flush, prime and paint. Eazy Cheezy up n Eazy !!
Some are over 20 years old and are still holding good.
PHOTOS will always get you more accurate information from the gallery.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
Users browsing this forum: Bing [Bot], toocrass and 91 guests
BoatCoversDirect
