It is currently 21 Mar 2019, 16:30
 Page 1 of 1 [ 10 posts ]
PostPosted: 25 Aug 2016, 21:45
File comment: The paint is failing in big pieces now.
So about 10 years ago I repainted my old 1970s Duracraft 16' flatboat using some "Duck Boat Green" paint that I picked up at a local old-time hardware store. Paint was durable, worked great, never had any issues with it. About two years ago while doing a big renovation I decided I wanted to repaint a dark gray. Couldn't get "Duck Boat Gray" and ended up using a enamel polyurethane paint that I picked up at Home Depot. Put it on with my airless sprayer and it looked great.
The inside of the boat is still fine, but I fish a lot of coastal salt marsh here in Louisiana and everywhere the paint has been in contact with pounding water, the paint has failed. The attached photo really shows it--it's flaking off now in sheets, like the adhesion is completely shot--even though on the interior of the boat it's still fine. Notice how the old Duck Boat Green is still holding on perfectly underneath my stinking gray!
What paint should I use for this boat that won't require a new mortgage on the house and still get the job done? I want to come back with a better gray paint job, BTW.
PostPosted: 26 Aug 2016, 05:08
Parker duck boat paint. They make a gray. It's about 53 buck with shipping. Call them directly.
PostPosted: 26 Aug 2016, 05:18
Scott85,
This is indeed the company that made the 'Duck Boat Paint" green that I have on my boat--I remember the can design now that I'm seeing it.
Thanks so much! This is going to save me a lot of research and money, these guys make an excellent product at a fair price. :)
PostPosted: 26 Aug 2016, 10:32
Did you rough up the green before painting it the last time? Paint doesn't like to stick to a smooth surface like it does to a rough surface. If yot take it to bare metal it likes a primer to stick to. Now saying that there are some good paints that may not need a primer to do the job you want it to do. In my experience some paints seem to get hard over time and can't take the flexing motion any longer.
PostPosted: 26 Aug 2016, 20:58
KMixon,
Yeah, I think I roughed it up sufficiently. I spot primed with a good rustoleum primer before spraying two coats of the top coat. I'm wondering if I need to get all of that gray off the bottom of the boat, just to be safe.
PostPosted: 27 Aug 2016, 08:01
gandrew55 wrote:
KMixon,
I would do my very best to remove all the old gray paint you can.
PostPosted: 30 Aug 2016, 06:59
Any paint is only as good as the surface prep, it looks to me like the surface was not prepped correctly, I would strip it all off before applying any new paint or else you will get the same results. Follow manufacturers recommendations to the letter.
PostPosted: 30 Aug 2016, 08:20
Yeah you'll need to get all that gray off or your new paint job will look terrible. I would recommend using a pressure cleaner to remove it
16' Polar Kraft Duck Boat in Progress
PostPosted: 30 Aug 2016, 13:48
I have a fine wire wheel that fits my angle grinder. I tested a patch on the side where the gray is flaking, looks like I can get it off without taking off that good green paint underneath.
PostPosted: 30 Aug 2016, 14:18
If the old gray didn't stick to the green paint, what is going to make the new gray stick to it?
Users browsing this forum: toocrass and 89 guests
mud-skipper
