What order of things?
DiverJosh82
Post by DiverJosh82 » 29 Aug 2016, 06:30
Hey guys,
Now that I got the entire hull stripped I am wonder what order I should be going in.. I'm going to gluvit so is that next? Or should I paint the exterior first, then gluvit? And should I build my interior frame first before every thing so that all new rivets through hull get gluvit and paint?
Heres what I'll be doing and maybe I can get some idea of what to do first-
Gluvit seams and rivets of interior
Painting of exterior
Painting of interior
All aluminum frame for floor and deck
Plywood floor and deck
Thanks for the help you guys!
Btw I've been going through the entire boathouse section, on page 242 currently lol
DaleH
Post by DaleH » 29 Aug 2016, 08:52
IMHO, for best results on bare aluminum, you should use an acid-etching zinc chromate primer before doing anything like Gluvit.
Gluvit is also an epoxy-based product and sun light and UV rays destroys it, so if not hidden it needs to be over-coated (painted).
#4 Procraft SV14
DiverJosh82
Post by DiverJosh82 » 29 Aug 2016, 12:19
DaleH wrote:IMHO, for best results on bare aluminum, you should use an acid-etching zinc chromate primer before doing anything like Gluvit.
Thanks for the reply
So you don't do gluvit on bare aluminum? Good to know. I'd like to primer it soon so it doesn't begin oxidizing. However I needto etch it first right? I used TSP the last time and it turned out really well. Looks like I'll be washing it one more time
