Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
Grizzly 1448 wont PLANE HELP!!!!!
mrdrh99
5
Post by mrdrh99 »
Man... I'm sure you can sell that ob and find a long shaft at a comparable price. Not that all the other stuff wouldn't help but if you plan on keeping that hull then just get the longer shaft.
Eat, drink, and be merry, for tomorrow we die
Post by richg99 »
Well, shucks, that is good news. Now you can just start with the weight distribution and hope that it works. rich
skipper123
Post by skipper123 »
Im not sure where the short shaft 15 " and 20 inch transom came from I did not read that from this post. If your planning fin on your motor is withen one inch of the bottom of the boat then BS you dont need a long shaft motor. You need one size smaller pitch on your prop so as to get your RPMs up, you are lugging the motor and have no pulling low end power. Dont listen to no BS get you a RPM gauge and set the RPMs where they are suppose to be by correct pitch and be done with it. The motor WILL plane the boat if its not wore out and has correct HP
A day on the water is what dreams are made of.
bassin0331
4
Post by bassin0331 »
I have no idea what pitch prop I have it's old and beaten uo
skipper123
Take it to a prop shop they usually have a few laying around to try out to see what RPMs your running. IF YOU buy your next prop from them. Yours is in bad shape you need one anyway. If ya dont have the option of a RPM gauge run a couple sizes down until you get her to plane. We ran a 20 on a 1648 Polar craft heavy boat for many years before we learned from all the experts we were under sized on the HP BS !
bassin0331
4
Well took it out today and moved some weight around and she planed out but still under to much load, ordered a new prop with smaller pitch so should be ready to rock, went 20 according to GPS but I know she's has more in her
Post by richg99 »
Great news..... if your prop was as damaged as you indicated...there was power/thrust being lost just there. Hope it works even better when you get the new one. richg99
Crazyboat
3
Post by Crazyboat »
I may be late to this dance but can you find a long shaft extension to add to the engine? It might prove to be the easiest fix in the long run.
1" above, we have to remember it's not a cavitation plate, it's an "anti" cavitation plate. Should be sledding or skimming across the top of the water or ever so slightly under. (1/8")
Skiffing
5
Post by Skiffing »
Just curious - what boat did this engine come off of? I think you need to know the engine
WOT RPM.
1. Difference in weight between the two
2. WOT RPM & speed each boat
3. Current prop
