Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
Need storage ideas
water bouy
3
Need storage ideas
Post by water bouy »
My 14ft vee will have to be outside for a while so i need to come up with a way to store the gear on the boat and keep it safe. I could build a long box but someone has probably solved this already. A removable top would be great and also keep out rain and snow.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
DaleH
5
Need storage ideas
Post by DaleH »
I've used anything from big old coolers ($5 at hard sale) to big plastic storage tubs, depends on your budget, how big you need it and if you want it locking.
I have a 2' square, 18" tall one where I put a piece of HDPE or cutting board material across the top, so now it serves as a cutting board or emergency seat (if cleaned, lol!). Added a hasp and combo padlock to it - simple & works!
Go to any big box store near you or tractor supply store, as I bought a big 'grain feed' box that I use for a bail of Timothy hay for the rabbit and it's big enough to store many items and was < $25. This one isn't solid enough to serve as a seat, but would be awesome for lightweight/waterproof storage!
#4 Procraft SV14
water bouy
3
Need storage ideas
A grain box is a good idea. I realized the two plastic barrels I'm using for saw horses might work if I can join two or three together and then split it down the middle so it lays over the seats and put two bottom halves between the benches with locks and hinges... along with a trail cam and a 'smile for the camera' sign.
