Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
Transom Plate/Pad
weweber3
3
Transom Plate/Pad
Post by weweber3 »
I know this is just like cutting board material... https://mud-skipper.com/accessories/transom-pad.html
Anyone use something like this (bolted through hull + 3M5200) on their boat?
Application is bow mount trolling motor or <10 HP outboard.
DaleH
5
Transom Plate/Pad
Post by DaleH »
Have used HDPE or LDPE (same as cutting board material) on many a small tin skiff as OB mounts at my boatclub. 6 or more maybe? No problems with any. We don't use trolling motors in the salt, so I can't comment.
TIP - Drill hole for fasteners over-size (e.g., 5/16" for 1/4" bolt) as those plastics move quite a bit with thermal changes ... high expansion/contraction properties.
#4 Procraft SV14
weweber3
3
Transom Plate/Pad
Post by weweber3 »
DaleH wrote:Have used HDPE or LDPE (same as cutting board material) on many a small tin skiff as OB mounts at my boatclub. 6 or more maybe? No problems with any. We don't use trolling motors in the salt, so I can't comment.
Are you filling the holes with the 3M marine caulk to fill up the gap? Seems like a no-brainer to do this to save the transom wood inside and out... especially when the transom wood is not easily replaced. I have seen some metal plates for this application, but cannot find anywhere to buy, hence the HDPE/LDPE.
DaleH
5
Transom Plate/Pad
Post by DaleH »
weweber3 wrote:Are you filling the holes with the 3M marine caulk to fill up the gap?
I did not, as my wood was fully sealed, actually encapsulated in marine epoxy. Even where I drilled through for the bolts, the wood holes were oversized and filled w/ epoxy, then drilled through for the bolts.
You could use any goop to seal them, but be AWARE that some silicone products contain acetic acid and shouldn't be used anywhere near aluminum.
#4 Procraft SV14
