Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
They call me crazy for a reason
Crazyboat
3
Post by Crazyboat »
I've always wanted to do this but would like your thoughts.
We can't help but notice that the toons on pontoon boats these days are getting larger in diameter, just to do one day after I retire I want to cut 2 of them open and drop in a jet ski engine and drive. If I get real crazy I could even go trip's on that bad boy. My biggest concern is if I went hard into a turn and one toon lifted clear of the water I could over-rev her (rev limiter anyone).
What are your thoughts on this wonderful idea of mine? Say anything you like. I have no emotion in this idea of mine.
lckstckn2smknbrls
Post by lckstckn2smknbrls »
Recently I have seen pictures of old bomber drop tanks being used as a boat with a long tail motor.
GTS225
Post by GTS225 »
Can't really be too much different than WW2 drop tanks being used for Bonneville salt cars. Cut it horizontally, build in a safety cage/frame, use what you like, and will fit for a drivetrain, and try to go fast on the salt.
Go for it. Start today, keeping an eye out for a single pontoon. Mount outriggers for stability.
Wait.....I just re-read your post. I looks like you want to put jet drives in both 'toons. I thought you were going for something fast on the water using a sinlge 'toon.
Not a bad idea, but you're going to have to allow for a servicing access panel, and a way to seal up said panel.
Lifting a 'toon is a consideration, but I'm not so sure you'd be able to do that in a turn. There's an awfully wide stance on those things. Now, breaking water jumping a wake might be more feasable.
Roger
earl60446
Post by earl60446 »
Submitting a drawing would help a lot. How are you gonna install a jet drive between 2 pontoons? 1 pontoon would not be stable.
Tim
16ft 1989 Fisher SV-2 w 1988 48hp SPL Johnson "CIGAR BARGE"
(engine looks like a wreck but runs great)
Used to have 1972 14ft Lund w 1977 15hp Mariner
(engine looked great but always ran marginal)
XLINE SPORTSMANS CLUB
Crazyboat
3
Post by Crazyboat »
Not a single jet drive, 1 drive in each toon, like a twin engine set up only with jet drives.
I'm thinking a hinged access panel on the toons with a good locking rubber gasket to keep water out.
juggernot
6
Post by juggernot »
I think it could be doable, with separate throttles you could steer by more/less throttle on the port/starboard engine w no need for a rudder/ers. But if one engine conked out you'd only turn wide circles. On second thought, having the pontoons sealed w a hatch/rubber could could turn them into long,shiny cylinder bombs w gas fumes trapped in them. That's why inboards have blowers and vents. I doubt you could get the boat certified, it would be deemed to dangerous.
Post by richg99 »
"They call me crazy for a reason"
Yes, Yes...I agree. Now I understand. THEY are right.
Dream on. You can do anything you want, but you may need a private lake on which to run it, so you don't kill more than yourself.
Ha Ha richg99
