Ice for my cooler
scoobeb
Ice for my cooler
Post by scoobeb »
Ok,maybe I posted in the wrong spot but here goes. I am going to start fishing 4 to 5 days a week in the gulf Coast here in fl,I have 2 coolers I need to pack with ice and buying 40lbs of ice 4 to 5 days a week will get I mean expensive. I need a way to keep my fish fresh for many hrs,anyone have a way to make ice packs or like some type of ice system they use ? I'm thinking of getting a ice maker now since I just bought the ice chest,It will run me near $16 a week times a yr,forget it,I will go broke,lol. I just bought some small tuber ware that are 4oz squares,my plan is to fill a bunch of them up and have like oversized ice cubes to use,I just hope the plastic holds up. Any suggestions?
Al U Minium
3
Ice for my cooler
Post by Al U Minium »
Build your own coolers, ask for information about ice and fish storage from the Florida Department of Agriculture. Use temperature monitoring device(s).
Ice for my cooler
Post by richg99 »
Hope you are that successful. Would a big live well keep them alive and fresh long enough?
I'm a catch and release kind of guy. Just started fishing in a very small local tournament (5 hours). Keeping the live well going, filled and freshened is a PIA. richg99
JMichael
Ice for my cooler
Post by JMichael »
Whether camping or fishing, we find it very useful to gather up a lot of empty 2 liter soda bottles. Wash them out, fill them with water (leaving a small amount of air in the top to allow for expansion), then toss them in the freezer. Of course this requires a fair amount of usable freezer space. When we get ready to go camping or fishing, we line the bottom of the chest with these frozen bottles and add a bag or two of regular ice on top of that. Now you can add all the food or fish they will hold and it will keep the contents cold for a few days. The bottles work similar to block ice and they keep the cube ice from melting as fast.
Edit: forgot to add, the reason we wash the bottles out is that the ice becomes cold clean water for drinking, cooking, or other needs as they melt, so we don't have to take along as much drinking water as we might have otherwise.
Pappy
Ice for my cooler
Post by Pappy »
Start freezing gallon milk jugs that are close to full of water. Allow for some expansion. Get enough jugs to allow you to stay ahead.
mrdrh99
5
Ice for my cooler
Post by mrdrh99 »
Pretty much the same as last post, I keep long flat Tupperware containers with the lid on, freeze them. At the end of the day, just a quick rinse and then back into the freezer every night. Takes up very little room. And always freeze a couple bottles of water to drink later in the day.
Eat, drink, and be merry, for tomorrow we die
oakchas
4
Ice for my cooler
Post by oakchas »
Freeze 2 liter pop bottles rinsed and filled with water. One liter bottles work too.
Leave room for expansion.
Once, when I was poor, our fridge quit. My chest freezer did have about 10 2 liter bottles of water in it. Used the fridge as an ice box for a couple of paychecks, rotating bottles.
Sent from my VS987 using Tapatalk
scoobeb
Ice for my cooler
Post by scoobeb »
I just went with a ice maker,makes to much sense to me. It was a 48lb a day ice maker I found brand new on ebay for $175. That will pay for itself 1000 times over compared to buying ice everyday and it takes up 0% space in my freezer except for my clean 5 gallon pal I have on the bottom of it filled with ice. I need roughly 40lbs a day,especially in this fl heat,ice does not last long so I went the ice maker route.
Ice for my cooler
Post by richg99 »
Sounds like a reasonably priced solution.
Good for you. richg99
KMixson
Ice for my cooler
Post by KMixson »
My sister who lives on a lake says the icemaker is one of the best investments they made living on the lake.
howl
3
Ice for my cooler
Post by howl »
I'd still put a frozen gallon jug in. Block ice lasts much longer. If I put one gallon jug in a Coleman 6-day the night before and fill it with rock fish the next morning, those fish will still be cold after lunch.
Also, since you have ready access to so much ice, it'd be a good idea to put ice in the night before to pre-chill the coolers. You can drain and top off before you head out. The ice will last longer since it doesn't have to cool the cooler insulation. Just things learned backwoods camping with no access to more ice.
sonny.barile
4
Ice for my cooler
Post by sonny.barile »
I watched one of those fishing shows on tv and I saw them stuffing the fish with ice cubes when they put it in the ice chest. Seems logical as it would cool the fish faster if the ice is inside and out.
Kismet
Ice for my cooler
Post by Kismet »
And..........
if you take some of the most-often-spoken-of blue board used for flotation and put together an insulation niche for the cooler, the ambient temperature will have a much more difficult time getting to the cooler and warming the ice. Don't even need to make it rigid; duct tape binding should work until you find if it is working.
Might be the first time in the forum's history when insulation is used to insulate something, instead of making it "floaty." :)
Best wishes. Be safe.
Kis
Enjoy every sandwich
1955 Alumacraft Model A
http://www.tinboats.net/forum/viewtopic ... 08&start=0
1959 Alumacraft Model F
http://www.tinboats.net/forum/viewtopic.php?f=3&t=25386
1980 Alumacraft Model F7, 1955-56? Johnson 10hp
http://forum.tinboats.net/viewtopic.php?f=4&t=35326
1956 Alumacraft Model RB
http://www.tinboats.net/forum/viewtopic.php?f=3&t=39249
Kismet
Ice for my cooler
Post by Kismet »
duplicate post
Kis
jethro
6
Ice for my cooler
Post by jethro »
sonny.barile wrote:I watched one of those fishing shows on tv and I saw them stuffing the fish with ice cubes when they put it in the ice chest. Seems logical as it would cool the fish faster if the ice is inside and out.
Well that's what the pros do with tuna. Pack them inside and out with ice. I seen it on Wicked Tuna!
I don't drink my tap water since I live in kinda an industrial area, so I buy gallon jugs of water. I drink them at home then when empty freeze them with the tap water. Then I cut it open with a razor knife and use an ice pick to break it up into big chunks. Some places are $3 a bag for ice! Not happening.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
