Acetone wash?
lvhish486
Re: Acetone wash?
Post by lvhish486 » 07 Sep 2016, 09:59
Scott85 wrote:Thanks Johnny I really appreciate your input.
Yes Johnny. Thank you very much for the input and knowledge. Let you know how it turns out.
Johnny
Acetone wash?
Post by Johnny » 07 Sep 2016, 11:02
Edit: to clarify primer vs bonding coat......
when I mentioned that "in my world" I would use KILZ, BullsEye or Zinsser primer,
If you read the literature on the products, they are "bonding coats" as well as
stain blockers for wood and drywall material (in the home).
On an aluminum surface with previous paint, it will provide a bonding coat for the
subsequent top coats.....
these products should NOT be confused with a corrosion preventative primer !!!!
in no way will they "prevent" corrosion..... only to assist the topcoats to bond with something else.
so, in retrospect, if you do have bare aluminum, you "could" scuff, sand, or rough up the surface,
vinegar or OSPHO treat the surface and apply a corrosion preventave primer first, if you want.
your call.
Read, Understand and Follow the instructions on any products you may use.
They are there for a reason.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
enginerd
Acetone wash?
Post by enginerd » 07 Sep 2016, 13:04
I should have noted that I took my boat to bare aluminum before painting and didn't have to worry about acetone softening any existing paint.
I did not use the self etching spray primer, but opted for the RustOleum Aluminum Primer in spray cans, which I believe is intended for use with their (RustOleum) epoxy spray paints. I think that spray Aluminum Primer might work better over your old finish, as opposed the self etching. I then put on a layer of bonding primer prior to spraying three layers of top coat.
"Fair Winds and Following Seas."
-Brent
lvhish486
Acetone wash?
Post by lvhish486 » 08 Sep 2016, 12:54
I'm looking to just use Rustoleum products for the interior (quick and easy), what kind of primer and paint would be best given the condition of my boat? The leaks have already been sealed with Gluvit and outside sealed with epoxy puddy.
This whole paint process is confusing #-o !
Trying to get this done this weekend so I can being the framing.
Johnny
Acetone wash?
Post by Johnny » 08 Sep 2016, 13:04
Go to YouTube !!!
search for - How to Paint a Jon Boat
:popcorn:
and that is a good idea to use the same brand of coatings
in a project . . . . you start mixing stuff up and that is aking
for less than favorable results.
Johnny
Acetone wash?
Post by Johnny » 08 Sep 2016, 13:31
OnTheWater - LOL - not that I have forgotten a lot of stuff,
it is the EPA LAWS that have changed so much over the years
that us Old Timers have a hard time finding something compatible
with our old school talents and skills. Such as lead based paints LOL.
and now, this stupid thing about "primer and paint - all in one can" is REDICULOUS !!!!
I was fortunate enough to attend a "Painters College" hosted by
Benjamin Moore Coatings many years ago and now - the products
we trained with are no longer available.
Even though I am retired, I still like to piddle with paints and coatings
while doing my domestic builds in the home as well as the vintage motors
and tin boats in my collection.
What worked well 10-15 years ago is not the case today.
HOWEVER (coma) the "technique" is the same today as it was 50 years ago.
we still have the option to spray, roll or brush things we want to paint or varnish.
I have been painting something or other or making signs since around 1960.
I was a woodcarving and painting instructor for my craft for over 20 years.
My fellow colleagues in the artisan trade are struggling with the same problems
generated by our government....... but, it is a necessary step to preserve our environment.
With all this in mind, it can very well be overwhelming to someone that does not
have past experience with painting - especially when trying to decypher primers and paints
like I said - it is only a BOAT !!! not your grandmothers china cabinet !!!!
DON'T OVER THINK IT
Scott85
Re: Acetone wash?
Post by Scott85 » 08 Sep 2016, 16:40
Johnny you my friend are a treasure chest of information and being retired navy is icing on the cake. Thank you for your service.
DiverJosh82
Acetone wash?
Post by DiverJosh82 » 09 Sep 2016, 20:35
I took mine down to bare aluminum only because I won't have a motor until next season and I figured what the hell.. But I washed it down with tsp and water solution, and after it dried I applied the gluvit, then I just scuffed if up (the gluvit) with some 220 and then washed it down with a 50/50 vinegar water mix. I am going to apply the paint for the interior tomorrow am. My question is does the vinegar water mix have any etching effect on the gluvit? Again I scuffed the gluvit but I thought if it did and it would help make the paint stick it would be good
I am going to be using self etching on my interior and I researched and it does not hurt the gluvit. I
lvhish486
Acetone wash?
Post by lvhish486 » 10 Sep 2016, 15:28
Some rust near the transom. Wire brush and vinegar wash? Do I need to prime this with etching primer?
Crazyboat
Acetone wash?
Post by Crazyboat » 10 Sep 2016, 16:23
Will the fix the OP used work long term or is it better to spot weld the cracks/holes?
Scott85
Re: Acetone wash?
Post by Scott85 » 11 Sep 2016, 14:28
Got the boat pressure washed this weekend.ImageImage
lvhish486
Re: Acetone wash?
Post by lvhish486 » 28 Sep 2016, 09:24
Scott85 wrote:Got the boat pressure washed this weekend.ImageImage
Scott, How is yours progressing? Did you decide to remove all your paint?
Scott85
Re: Acetone wash?
Post by Scott85 » 28 Sep 2016, 09:57
you don't want to know!!! I didn't like how the paint turned out on the trailer so I just got done sanding and painting the trailer again.
