It is currently 24 Mar 2019, 06:46
SwampRunner
 Page 1 of 1 [ 7 posts ]
PostPosted: 12 Sep 2016, 11:27
I found a poly livewell the right shape at the right price except it could be longer than 19". If I bought two of them, is there a way I could join them together? Maybe overlap them and use marine caulk?
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
PostPosted: 12 Sep 2016, 11:41
I would not trust caulk to hold them together. If they are the same size they will not overlap real well. One will try to bend inside the other. When you get water added to it the weight of the water will stress the caulk too much and it will come apart. There are plastic welders out there that would do the job better in my opinion than trying to overlap it and caulk it. They will melt the original poly while adding more poly to strengthen the joint. You can even use a screen wire to melt into to joint to give it a very strong joint. I have a plastic welder and it works wonders in some situations like this.
PostPosted: 12 Sep 2016, 15:31
I didn't know plastic could be welded but it sounds like a great idea. I could possibly make my own livewell after I found a place called Alro this morning. They carry poly and metals at very reasonable prices.
Wonder if something like this would work:
http://www.homedepot.com/p/MPG-30-in-L- ... /206420074
PostPosted: 12 Sep 2016, 16:16
Bouy, there is a thread here a few months back
about a member that had to shorten his tank
by 8" or so . . . and gave a step-by-step.
viewtopic.php?f=3&t=40820&p=413724&hilit=shorten+livewell#p413724
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 12 Sep 2016, 16:36
A planter is a bad idea.... sounds like you should consider something in the farming realm ?
http://www.ebay.com/itm/New-Polyethylen ... xy5rpSOLGl
http://www.agrisupply.com/oval-tank/p/54748/
PostPosted: 12 Sep 2016, 16:44
Found it. He did a great job.
PostPosted: 12 Sep 2016, 21:14
This one may be functional:
http://www.windowbox.com/window-boxes-p ... rs-10.html
Users browsing this forum: Davidr61, Mzzy and 85 guests
TheRescueStep
