It is currently 25 Apr 2019, 05:46
BoatCoversDirect
 Page 2 of 2 [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Vhull deck framing
PostPosted: 17 Sep 2016, 11:33
Tim, if you are having trouble with the actual construction process with design, function and safety,
just start making some simple pencil sketches of what you would like to see in your boat.
then, cut some cardboard and start mocking up the plan to see how you like it.
Cardboard is cheaper than cutting plywood only to find out it is not what you envisioned.
It is very difficult for anyone with limited woodworking and metalworking experience
and hand tools to get started in the right direction.
If you need a visual tutorial of how to get started, try viewing some boat mod videos on the
good old YouTube . . . there are many good videos of how to get started, what tools
and materials to use, and so forth..... this may help you understand the process required
to make your boat like you want it and make it SAFE........
go to: http://www.youtube.com and put "boat casting deck build" in the search box.
we hope you can make a really great project out of your boat
some of the hand tools you must have (more or less).
hammers of different sizes
hand drill with assorted size bits
hack saw
coping saw
jig saw with wood and metal blades
skil saw with carbide teeth
pliers and wrenches
saw horses - milk crates -
cardboard for patterns
whole bunch of stainless screws, nuts and bolts, yada yada yada
and this is by far NOT the entire list (other members will add more)
and above all, you need a PLAN
and PATIENCE PATIENCE PATIENCE
and - don't get frustrated if things don't fit the first time.
if you bite off more than you can chew - slow down, take a breath and regroup.
Photos of what you are asking questions about help enormously.
good luck !!
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 17 Sep 2016, 16:03
Got all the tools my friend owns a wood shop just trying too find a good deck frame lay out that I like close too my boat
PostPosted: 18 Sep 2016, 10:04
Tim, is there a marina, boat launch or boat yard in your area
that you can visit and maybe get some ideas ?
Did you google V Hull Jon Bass images or V Hull Casting Deck ??
I see hundreds and hundreds of very fine examples there.
http://www.bassresource.com/bass-fishin ... 14-v-hull/
is just one example..........
your carpenter friend may have the skill to design something for you and help with the fabrication.
A good woodworker is an invaluable asset when it comes to messing around with old boats.
how about a trailer ? how will you be getting your boat to the water?
If your plan is to transport your boat in the back of a truck, once you
start adding all that wood and weight, it could be a LOT of work.
Users browsing this forum: Bing [Bot] and 42 guests
SliderG5
