It is currently 18 Apr 2019, 17:01
BoatCoversDirect
 Page 1 of 1 [ 7 posts ]
 Post subject: TM Prop Removal Help
PostPosted: 19 Sep 2016, 09:59
I have an older Motorguide Tracker Pro-Series 40 that I'm trying to get the prop off of. Have taken the plastic prop nut off, but cannot get the prop off the shaft. Is there a trick to it I'm missing? I want to see if the props on either of my 2 transom mount TM's will fit it so I can take a spare with me on a little trip I'm taking next month.
FWIW, this isn't my video, but this is the TM I have.
https://www.youtube.com/watch?v=dHZHHqhBykI
BigTerp's Tracker Sportsman 16' build-------> viewtopic.php?f=21&t=26774
PostPosted: 22 Sep 2016, 06:03
I would try tapping the prop with a small hammer & block of wood, and pentrating oil. Prop is propbably corroded onto the shaft.
PostPosted: 22 Sep 2016, 11:03
have you tried PB blaster?
PostPosted: 22 Sep 2016, 11:52
Sorry, forgot to update. Thanks for the replies!! I got it off with a little coercion from a rubber mallet. Found why it was so hard to remove. There must have been 100 yards of line on the shaft :shock:
PostPosted: 22 Sep 2016, 19:04
It is a good idea to frequently remove a tm prop to check for line build up. Just in case . It hides under the prop robbing power.
PostPosted: 23 Sep 2016, 08:33
timsmcm wrote:
It is a good idea to frequently take of a tm prop to check for line build up. Just in case . It hides under the prop robbing power.
Will now be part of my routine. Thanks.
PostPosted: 24 Sep 2016, 16:24
More than robbing power, fishing line can cut through the prop seal and let water get into the motor. Braid is especially bad.
Always told my kids....If.... "Somebody ought to do something" comes up....remember...you are "SOMEBODY" !!
Users browsing this forum: Google Adsense [Bot], jasm2, Jebber, tintweeker and 66 guests
BoatCoversDirect
