Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
Transom Top Lip
brassyb
3
Transom Top Lip
Post by brassyb »
Inherrited a Lowe 16 Superior-V a few weeks ago, and have been working on getting it back into shape.
Got some aftermarket foam blocks removed from the back that were totally waterlogged so I could get to the transom, and when I finally got it all apart, I found out the top lip is all torn up.
Here are some pictures:
https://imgur.com/a/UHooT
My thought was to install the new wood transom, and then get a sheet of aluminum shaped to fit over the old torn up lip, and maybe 5" down on either side, and through bolt it to the new transom.
Anyone see any problems with that? I've got a Johnson 20R73A 20 horse outboard for it, so it's not a huge motor.
Thanks for providing such an awesome resource.
lckstckn2smknbrls
Transom Top Lip
Post by lckstckn2smknbrls »
I'd cut off the old cap and make a new one. It only has to come down an inch or so.
brassyb
3
Transom Top Lip
Post by brassyb »
Would you have it welded on? or just through-bolt to the wood transom to hold it in place?
DaleH
5
Transom Top Lip
Post by DaleH »
brassyb wrote:Would you have it welded on? or just through-bolt to the wood transom to hold it in place?
The original tin U-shaped channel trim cap was nailed on using aluminum ribbed nails. That would certainly work. When I redid my new transom, I used heavy wall 1-1/2" in the 'U' aluminum channel, bolted on w/ properly sealed and insulated SS bolts.
You should be able to get replacement aluminum ribbed nails from Starcraft customer support! Andy was phenomenal with the support he gave me when I went to replace not only the wood, but both the insode and complete outside tin skins.
#4 Procraft SV14
