Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
Nobility Scale
Pappy
Nobility Scale
Post by Pappy »
Have seen a bunch of posts about "what screws do I use in Aluminum" etc. and a bit here and there about corrosion between metals.
Guys and Gals, there is a simple scale out there called a Nobility Scale that rates (metals) from anodic (corrodes away) to cathodic (sticks around).
Take a look at any one of the scales on the web and pick out the metal you want to fasten to and find the metal closest to it on the scale for the attaching hardware.
The closer together the metals are the less potential between them. The farther away from each other on the scale the more potential (or corrosion)
Pretty simple!
https://www.corrosion-doctors.org/Defini ... series.htm
Kismet
Nobility Scale
Post by Kismet »
This should be a sticky.
TYVM, Pappy.
Kis
Enjoy every sandwich
1955 Alumacraft Model A
http://www.tinboats.net/forum/viewtopic ... 08&start=0
1959 Alumacraft Model F
http://www.tinboats.net/forum/viewtopic.php?f=3&t=25386
1980 Alumacraft Model F7, 1955-56? Johnson 10hp
http://forum.tinboats.net/viewtopic.php?f=4&t=35326
1956 Alumacraft Model RB
http://www.tinboats.net/forum/viewtopic.php?f=3&t=39249
surfman
Nobility Scale
Post by surfman »
Humm, according to the chart Steel is a better choice than SS.
