Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
OSB for decking and floor?
JC2133
Post by JC2133 »
Will OSB work for flooring and decking if sealed with spar urethane (3-4 coats)?
Here is the OSB I was looking at:
https://m.lowes.com/pd/7-16-CAT-PS2-10-O ... 8/50382768
surfman
Post by surfman »
It will probably work, Urethane is not all that great though. Are you going to leave it bright or carpet it. I think I would also paint it with a good marine enamel on all sides especially the edges.
lckstckn2smknbrls
Post by lckstckn2smknbrls »
I wouldn't use it. Look for BCX plywood.
Johnny
5
Post by Johnny »
- no -
UNLESS !! you seal it well and NEVER let it get wet !!
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
onthewater102
5
Post by onthewater102 »
Chances are the glue holding it together will fail if it gets wet - hence it not being rated as an exterior material or flooring material.
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
JC2133
Post by JC2133 »
Thanks for the responses
turbotodd
Post by turbotodd »
OSB sheeting will sometimes fall apart when painting it. Put it anywhere near water and it just turns to soft mushy wood chips. Found this out the other day...I made a ramp to load my pit bike in teh trailer, out of a pair of 2x4's and some OSB between them. Had it in the shop already so I used it. Left it out in the rain, mind you, it was not a "rain", more of an intermittent sprinkle. Stuff just fell apart yesterday when I realized I had left it out and attempted to move it.
