painted deck
h2ojohn
painted deck
Post by h2ojohn » 02 Oct 2016, 10:27
I have a '95 TX17 that needs carpet, thinking about just ripping the carpet out and painting it with non-skid paint. Has anyone else done this? Pros and cons
overboard
painted deck
Post by overboard » 02 Oct 2016, 11:49
I didn't have the carpeting, but painted the decks on my build with non-skid paint. I like it that way, but I do most of my fishing in spring and fall when the deck doesn't get that hot.
water bouy
painted deck
Post by water bouy » 02 Oct 2016, 13:32
I tried it and it's very hard after the second coat. The only problem I can see is if it's penetrated by a screw it probably needs caulk of some kind. I used cheap foam brushes and was not able to get it very smooth at all.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
painted deck
Post by BigTerp » 03 Oct 2016, 09:15
I used Asper Grit with Parkers Duck Boat Paint. Has held up well and it's still nice and gripy three years later. I did the "broadcast method". Sprayed on the paint with an HVLP gun, sprinkled the Asper Grit over the wet paint and then applied a second coat of paint after the first dried.
I got the quart size and only used about half of it on my 1648.
http://www.softsandrubber.com/aspergrit.html
overboard
painted deck
Post by overboard » 03 Oct 2016, 11:24
[quote="BigTerp"]I used Asper Grit with Parkers Duck Boat Paint. Has held up well and it's still nice and gripy three years later. I did the "broadcast method". Sprayed on the paint with an HVLP gun, sprinkled the Asper Grit over the wet paint and then applied a second coat of paint after the first dried.
Actually that's similar to what I did, I didn't buy the actual non skid paint but added the grit to some of the paint I was using, stirred it up good, dumped some into a pan and then applied it with a roller, mixed again, put some in pan, etc. etc. until done. Trick is to keep mixing so the grit doesn't settle.
painted deck
Post by BigTerp » 04 Oct 2016, 08:55
overboard wrote:Actually that's similar to what I did, I didn't buy the actual non skid paint but added the grit to some of the paint I was using, stirred it up good, dumped some into a pan and then applied it with a roller, mixed again, put some in pan, etc. etc. until done. Trick is to keep mixing so the grit doesn't settle.
This also works well. I took the leftover Asper Grit I had and mixed it in a gallon of paint. We used it on the floor of my buddies trailer that we use for goose hunting. Had enough left over to do his steps coming off his back door to his deck. Stuff goes a long ways.
