galvanic corrosion
alwayslookin
3
galvanic corrosion
Post by alwayslookin »
I am putting together the transom on A 17" bluefin. The question I have is will a fiber gasket behind the bolt heads and washers help eliminate the corrosion as this boat will see mostly saltwater use? I am sealing all through hull fasteners with 5200 as I am putting it together, was just thinking the gasket may help. Any/all input is greatly appreciated. Thanks all
DaleH
5
galvanic corrosion
Post by DaleH »
Sure it will! Anything non-metallic to insulate the SS from the aluminum will work.
#4 Procraft SV14
Pappy
galvanic corrosion
Post by Pappy »
But - To fully insulate the through bolts you would also need a non-conductive bushing. Your idea will help though.
Al U Minium
3
galvanic corrosion
Post by Al U Minium »
I have used 5200 to coat the bolts, washers, nuts, the hole they go through, clothes, me, tools. When you have torqued the bolts, wipe off the excess 5200 and you will be good for years, Do not use fiber washers, nylon, etc. The bolt up fasteners will always move even if it is just from thermal expansion and contraction. The 5200 provides the barrier that will stay in place.
mbweimar
galvanic corrosion
Post by mbweimar »
The gasket most likely won't withstand the compression of the engine bolt. I used regular automotive silicone on my boat, and after 3 years of saltwater use I pulled the engine and all was fine.
2013 Weldbilt 1752V
ETEC E40DSLSE
Molokai
3
galvanic corrosion
Post by Molokai »
I was thinking of doing this same thing using some hypalon patching material i had laying around. That stuff is really durable.
Lowe L1648M, Yamaha 15c
DaleH
5
galvanic corrosion
Post by DaleH »
Pappy wrote:But - To fully insulate the through bolts you would also need a non-conductive bushing. Your idea will help though.
I've put adhesive-lined heatshrink over bolts with good success, although crevice corrosion will still occur.
mbweimar wrote:The gasket most likely won't withstand the compression of the engine bolt. I used regular automotive silicone on my boat, and after 3 years of saltwater use I pulled the engine and all was fine.
FYI, most regular silicones are made with acetic acid, which attacks aluminum.
#4 Procraft SV14
alwayslookin
3
galvanic corrosion
well, I'm gonna do it! I have a 12"x24" piece of 1/16" gasket material going to use a 30-30 shell to cut the inside hole and a piece of 1/2 tubbing sharpened with a file to cut the outside diameter. For the other odd shaped things just trace an outline and get out the razor blade. Just gotta get it done in all my spare time. HEHE
DaleH
5
galvanic corrosion
Post by DaleH »
Believe me, I have even used DUCT TAPE as an insulating material to prevent GC where SS hardware was used on a tin boat and good ol' duct tape works! Not pretty years later ... when I took it apart, but the parent material (properly prepped and primed of course) was still integral with ZERO corrosion issues.
FWIW, https://www.clipsandfasteners.com/Nylon_Flat_s/211.htm sells nylon washers in bulk in all diameters and thicknesses. When I re-did my complete new transom (new tin skins AND new core) the OEM Starcraft methodology had used 32 SS bolts, IIRC, tying the rear skin to the splashwell and inside skin. Using the nylon washers with the bodies and bearing surfaces coated with Tef-Gel sure made it protected (against corrosion) and FAST work!
#4 Procraft SV14
Pappy
galvanic corrosion
Post by Pappy »
Dale - That adhesive backed heat shrink is one Hell of a good idea along with non conductive washers...thanks!
Buckethead
galvanic corrosion
Post by Buckethead »
I used nylon washers with SS hardware and 5200. Used a little extra 5200, ran the nuts down to the point where the nylon was just starting to flatten the 5200. Let 'er cure for a week before you tighten them down and should be bulletproof. I did my transom in late 2012-early 2013, no troubles to date.
