Way Past A Basic Re-Carpeting Job?
DacMan
5
Post by DacMan »
I understand how to re-carpet a boat on the basic level. But my Lowe 170 has compnents that appear to have been carpeted then rivetted in place to make the deck. I've included pictures. How do I do it?
DacMan
5
Post by DacMan »
Rod box attached to deck
DacMan
5
Post by DacMan »
Also the gunnel is trimmed in an odd way. The deck and the gunnel meet and seem to have a carpeted trim at the joint. Pic below
Johnny
6
Post by Johnny »
eeeewwwwwww that's gonna be one tough job.
I redid my 16' Bluefin and it was done correctly by the P/O.
yours looks like a total tear out and maybe drill out all the rivets
and replace them before the new carpet.
Rivets ON carpet ?????? that is a new one to me.
suggestion: after carpet removal, put a propane bottle torch
to the rivets and see how easy it is to melt out any carpet remnants
to see how tight the rivets are set....... if you are lucky, they will
all be tight and you can carpet over them without loosing any
structural integrity. That would be totally your call.
https://www.tinboats.net/how-to-build-a-transom/
https://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = https://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = https://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
DacMan
5
Post by DacMan »
Thanks for the reply, it is an odd setup, looking at the boat I'm confident they installed carpet on many of the compnents before installation, and that's why it's riveted over the carpet. Considering the value of the boat maye I should just leave it be.
ericman
Post by ericman »
Lunds are the same way. Completely re-doing all that will be a major headache. Good Luck!
lovedr79
Post by lovedr79 »
thats a new way to do it! i would go ahead and invest in a rivet removal bit and get to drilling.
jethro
6
Post by jethro »
My Starcraft is that way. I'm pretty sure it's factory.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
DacMan
5
Post by DacMan »
So basically I will need to drill all the rivets out and remove the compnents, carpet, and then, reinstall the conponents?
Johnny
6
Post by Johnny »
yep
DacMan
5
Post by DacMan »
Last question, what do I do if I want to use a front deck pad? I can't expect a rivet to hold compressing both carpet and a pad right?
