rub rails or protection for round top rail
timsmcm
Post by timsmcm »
Is there something made that works as a bumper for the top rail? I have a lowe boat and it has a round top rail. When I tie off to a bridge pier it is hard on the boat. Any suggestions?
Johnny
5
Post by Johnny »
Tim, do you have any issues of drilling holes in your boat ?
I have seen 2 and 4" fire hose split down the middle and fastened
to boat rails with stainless screws. Easily replaced when they wear out.
Ebay = $1 a foot
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
timsmcm
Post by timsmcm »
That is almost what I thought about doing except using 5200 to attach the hose. But I have no problem using screws to attach said hose. What screws would you use?
surfman
Post by surfman »
What about splitting a piece of PVC pipe and forcing it over the rail. It would be hard but doable, you could use the grey stuff if you don't like the white.
lovedr79
Post by lovedr79 »
i have seen firehose and PVC pipe used.
DaleH
5
Post by DaleH »
I once split some white rubber 'sanitation' hose of 1-1/2"'diameter in half, cut down one side. Took an old jig saw blade and snapped it shorter so I could use the power tool and then held the hose in my Black & Decker tool mate bench. Made the cut pretty fast! Just try to keep your cut on the INSIDE of any natural bend to the hose. I found that by putting a 1/2" line using a Sharpie marker every foot worked slick!
I just secured it to the rail every 6" with good quality zip-ties. Worked slick, was cheap enough and is still in place a dozen years later, although clearly zip-ties have been replaced. I could have pop-riveted it in place, but it is a work skiff for a private club and being 'volunteers' to add the rub rail ... we were ... well, lazy!
#4 Procraft SV14
Johnny
5
Post by Johnny »
Tim, in my world, I have no second thoughts about using
brass screws - - I would scrounge up a 50ft hose from where ever
and split it open. Then, measure the two thicknesses with the
boat hull and purchase a box of brass round head machine screws, washers,
and nuts. #10x1" or 3/4". If you want to go stainless, that is up to you.
I will not enter the brass/bronze/copper/galvanized debate.
Personal choice as to cut off the excess of the screws or not for a neat, safe appearance.
and yes, fire hose CAN be painted with any paint - match your boat if you wanna.
self tapping screws pose a safety/snag hazard as well as rust (eventually).
It ain't rocket science - it's a boat.
Fire Hose.png (3.72 KiB) Viewed 991 times
wmk0002
5
Post by wmk0002 »
I have been thinking about asking this for a while too. Can someone provide an Ebay link to the product they would choose?
http://www.tinboats.net/forum/viewtopic ... 21&t=40764
Johnny
5
Post by Johnny »
for fire hose ??
go to e-bay, in the search box, put in "FIRE HOSE". many will pop up - - - -
put in the size you need: 2", 2.5", 3", 4", etc
and it will refine your search. hundreds of the 1 and 1.5" available.
some used, some new, some you pay shipping, some you don't.
you want to look at the older COTTON outer cover.
the nylon outer cover may (or may not) fray and get ugly with abrasion.
Then again, you can put the inside rubber on the outside - your call.
with a tape measure, see what will work for your boat.
obviously, a 1-1/2" won't work, not enough skirt to bolt through.
4in fire hose.JPG (24.55 KiB) Viewed 981 times
https://www.ebay.com/itm/4-x-18-Single-j ... jKGvHdxIjQ
https://www.ebay.com/itm/4-x-46-ft-FIRE- ... xy7AxSKjsq
wmk0002
5
Post by wmk0002 »
Johnny wrote:for fire hose ??
Thanks! Upon second thought though, I'm not sure the fire hose would be the best option for me. Similar to the OP my issues come when tying up beside concrete walls or columns which are really rough and coarse which may chew threw the hose really fast. I had been leaning towards pvc in my mind previously.
