It is currently 19 Mar 2019, 23:44
SwampRunner
 Page 1 of 2 [ 23 posts ]  Go to page 1, 2  Next
PostPosted: 11 Oct 2016, 14:05
I have a 1988 16' Alumacraft Lunker with a 40 HP tiller Merc that I want to convert into a center console boat. It has a deck now but the decking is screwed to the aluminum supports in the floor, which makes for lots of screws working their way out. As part of the conversion, I'd like to know how to create a better deck-to-hull connection, how to properly prepare the hull for the conversion (e.g. should I remove and replace all the flotation?), how to properly mount a center console to the deck or hull, and how to properly run steering control cables back to the motor. To be honest, I know absolutely nothing about how to approach this project or work with aluminum. I'm retiring in a few weeks so this is a retirement project and I have the entire Winter to complete it. I have a line on a 25hp Evinrude with controls so I'll just take off and sell the Merc and replace it with the Evinrude. I'd be grateful for any and all suggestions about how to approach this project. Many, MANY thanks in advance for whatever anyone would like to offer, in terms of guidance.
Smoky
PostPosted: 11 Oct 2016, 22:05
This is a different project than any that I've done. I only have a comment or two.
Smarter people than I will be on board to help, soon....(I hope).
One boat that I had had a center console that was affixed to the deck with 3M5200. Yes, it was also screwed down, but I am convinced that the 3M5200 would have held in a hurricane.
Most everyone on this site that lifts their decks finds waterlogged foam. It adds weight and doesn't help much if you were to get swamped. I'd replace it.
There are items called rivet-nuts. They can be pressed into place and then bolts secured to them. Check Youtube and you will find a number of good videos, including some that do not call for any special tools for installation.
I'll leave that topic for people smarter than I.
regards, and welcome aboard. richg99
Always told my kids....If.... "Somebody ought to do something" comes up....remember...you are "SOMEBODY" !!
Online
PostPosted: 11 Oct 2016, 22:36
Thank you kindly, Richg99...great advice!
PostPosted: 12 Oct 2016, 19:39
welcome Smoky
you will find that as you float along with us in the pond,
photos will always help with your build.
there are dozens of good threads here that deal with
fastening the deck to the hull. Just read up and see
what will best fit your application.
and a personal note: after you get the deck secure,
assemble all your cables and controls and try several dry fits
BEFORE you go and making the console permanent.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 12 Oct 2016, 21:35
Thanks, Johnny! I'm thinking center console so I can fish around it. I was thinking that I would need to run the cables under the decking but you seem to be saying that's not a good idea. Correct?
PostPosted: 12 Oct 2016, 22:42
No, it's a better idea to leave them laying in the floor of the boat so you and everyone else in the craft can trip over them while fighting a big fish.
PostPosted: 12 Oct 2016, 22:51
Hey moron...I'm new at this. If you can offer me some intelligent advice, do so. Otherwise go open up a great big can of STFU and drink it.
PostPosted: 12 Oct 2016, 23:19
With only 4 posts, from the new kid on the block, you might want to put your big-boy pants on and lighten up. You'll get further around here.
Thin skins are for liberals.
PostPosted: 13 Oct 2016, 00:12
I'm just about to tackle this project myself on my Weldbilt. I had a piece of .125 aluminum welded between the ribs on my boat, and cut to the exact size of my console. Ignore the leaning post in this pic.
My floor will be laid down on top of this, then I'll use rivnuts to fasten the console down to the floor and plate below. Here's a quick pic I snapped the other night while cleaning up after the hurricane. Nothing is mounted yet, just a mock up.
2013 Weldbilt 1752V
ETEC E40DSLSE
PostPosted: 13 Oct 2016, 00:22
PATRIOT...I'm here for solid information, not to join a fraternity or appeal to anyone's political interests. That said, trolls and cyber bullies like our little buddy here typically use forums as an excuse to express their inner 3rd grader, and can ruin otherwise good forums. I'm quite sure there are lots and lots of good folks here who can help the less experienced like me and, at the same time...unbelievably...do so respectfully. I really don't think that's too much to ask.
PostPosted: 13 Oct 2016, 00:26
mbweimar..thanks for posting the great pics! I'll look forward to more...and I'll post my own as I wade into my project.
PostPosted: 13 Oct 2016, 08:34
No problem. I'm sure it will be several weeks before I make any measurable progress. The weather down here in South Florida is only just now starting to become tolerable. I still have to flip my boat back over on the trailer and spray one more coat of paint on it before I start on the inside.
2013 Weldbilt 1752V
ETEC E40DSLSE
PostPosted: 14 Oct 2016, 13:47
My Lowe came from the factory with the center console riveted to the flooring. I moved it forward 2 feet to get better weight distribution up front. You want to make sure you get the front of the console into the floor crossbracing(ribs). I used some boat caulk as well and it holds pretty good. I'm not sure it would hold up to someone really large using it for bracing but you would probably need extra floor ribs for that. My cables run out the bottom of the console and on the floor then up the side and back to the motor. I would have needed to remove the flooring to run the cable underneath.
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
1993 Jetcraft 13' sprint boat with Chevy ZZ3 350 engine and Hamilton 772 jet drive
PostPosted: 14 Oct 2016, 14:20
JL8Jeff, thanks for that advice! If you have an opportunity some time, I'd sure appreciate seeing a photo of how you ran your cabling.
Thanks again...Smoky
PostPosted: 14 Oct 2016, 17:59
Because my console is so close to the front deck, the cables run pretty close to the deck so when you step up or down from the deck you step over the cables.
Users browsing this forum: CTilton, jay57, lckstckn2smknbrls, Majestic-12 [Bot] and 109 guests
mud-skipper
